Golf PD150 (diesel) - black smoke on boost
Hi all,
I have a Golf 150 diesel remapped on a 2002 plate. And recently noticed its starting to give more than normal black smoke when on boost. I've also noticed a louder induction sound and when coming off the gas a louder than normal dump valve type of sound (no after market dump valve fitted).
I've checked the following:
Air filter - was ok
Boost hoses - were ok
The only thing i can think of is leaking injectors its done 90k
any thoughts?
Thanks
Bobby
Air filter - was ok
any thoughts?
Thanks
Bobby
Shove some MILLERS DIESEL CLEANER in there, works ace it does.
Then try running a tank of BIO DIESEL as this has a natural cleaning action as well, it also goes a lot better on it.
very common probelm on the golf tdi 150 is the cam lobes wear and doesnt open the valve properly.
it has happened to 2 of my friends cars with the exact same probelm as yours, you will need a new set of lifters and a new camshaft
take your rocker cover off and check each lobe and each lifter
the same thing happened to me it a month after i fitted a tuning module tried all the same things u tried turned out for some strange reason it had jumped the timing slightly
you wouldnt put 2star in a cossie would you ?
the PD will die on bio.
you said you had checked the boost hoses?
Just glad its a pipe rather than the turbo or something even though i bet the pipe aint gona be cheap.
alex
alex
and the pipe will have split because the brake reservoir cap will have rubbed it away.
alex
Proven Legendary Status
I thought split pipe too.
If you look in the flap for the filler neck you will see a sticker that says "Bio Diesel" and a cross through it. Given that VW spend a few quid on developing the engine, I suspect that as PD runs very high pressures compared to older Diesels theres probably a good reason for their decision.
i work for a large user of PD engines and have found bio and PD dont work together
but the filler thing on the 335d says no bio diesel
JK12
33
26-04-2021 12:09 PM
