Sky+ Box to PC Monitor...
Yellow RCA (composite) carries video only, but be warned it's ABYSMAL quality (lowest quality you can get next to RF aerial modulation) so for sound you would need L+R (red and white) audio RCA inputs on your soundcard....
To convert a scart output (or S-Vid, composite etc) you need a video to VGA converter like this;
http://cgi.ebay.co.uk/TV-tuner-box-V...QQcmdZViewItem
Plug your Sky box's s-vid or yellow RCA into this box, then the box into the PC monitor (goes directly into the monitor, so you wouldn't be able to view the desktop at all as you would have to disconnect it from the PC) and the audio from the Sky box needs connecting to an amp or hifi....
Dojj - AFAIK, the UB port is redundant - so you can't use it for data transfer from box to PC.... It was used on some boxes for firmware updates and so engineer service, but I don't think they bother anymore, as most are updated if need be over satelite or via the phone line (ala Sky+)
The other reason you can't tranfer recordings to PC is they aren't recorded like a video you watch on your PC (like MPEG etc) The Sky box just records the data transmission of the programme then replays this, it's doesn't encode to a video codec.....
Right after a little investigation of my own....
Is it one of these i need to sort it out?
http://www.maplin.co.uk/Search.aspx?...source=15&SD=Y
Red/White/S-Video into Sky+ box and the S-Video/Phono into the desktop sound card?
Yes, if your PC has a TV card with S-Video INPUT then you should be okay. YOu should have an audio input as standard on the built in soundcard, tho you might have one on the TV card aswell, and if you do, use this one.....
YOu might need software to view whats being inputted through the TV card, but this you should already either have, or be easily findable on the net
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
