Stu, she just loves a bit of boost! ;)
Car has had about 50 miles on and off boost tonight up to the no go zone and just loves every minute of it. Pulls really well for 14lb. 1st and 2nd are deffo useless in this weather and 3rd is a little twitchy over bumps.
Would we be able to overcome the fueling issue using a 5th injector controler and the cold start valve or is too great a deficit meaning we need a bigger injector?
PassionFords Creator
Im glad your getting some fun out of her mate, youve invested enough in it
To answer the question:
We probably could, as its only a slight fuel deficit. If you want to try it let me know.
Originally Posted by XRTypeRS
Glad she finally going Daz, Im sure all the work has been worth it!!
What boost are you planning to run then?
Hmmm, somehow I get the feeling your car is going to be a bit of a serious weapon!!
Just dont torquesteer into a ditch after that amazing bodywork job!!
Good luck mate!
Good luck mate!
Kin ell Daz - ur overtakin me lol. Whats up - 14psi all she can take on the std KE? Shows how much air its takin Im on 10psi at the mo, all std chip will let me have and its rapid lol. Got another turbo to go on now, but driving it too much to do any work. Might leave it till next year now.
Other than that it comes on boost and just pulls really smooth.
Dead and Gome, hi mate. I never got your name. While you're around, I am available next sat to do that wiring but not the saturday after.
depeds on how rich she is at idle i guess. Maybe u can afford a 1/8 turn on the reg? Will be interesting to see what happens to mine at a bar
We still need to dial in a bit of ignition jet. On that respect, yours being similar spec to mine should be pretty good.
CabrioTurbo
01-08-2015 11:04 AM
