Cosworth engine spec help
Old Jul 18, 2007 | 10:40 PM
cosy trav's Avatar
cosy trav
Default Cosworth engine spec help
Im currently rebuilding my engine and wondered which cams and injectors to use .
the spec so far .
200 4x4 block , Low comp balanced bottom end ,4x4 inlet manifold + fuel rail ,2 wd ex manifold , escort cosworth head standard , GRP A coil ,oil breather , fuel pump , cam belt .TT38 0.63 ex housing T4 comp wheel 360 deg bearing .
L8 ecu , closed loop ,thats it so far , im looking for 470 bhp .
any advice would be great especially if ive missed something .
Thanks Travis.
Old Jul 18, 2007 | 11:03 PM
ECU Monitor Enthusiast
Give Stu @ MSD a phone call in the morning ...
http://www.remapping.co.uk
He is an expert with the L8 and has some unique options
He may have an off the shelf solution.
Probably.....
You will need bigger injectors than greys for that BHP and he will
probally recommend siemens types (4 off).
The standard head MAY be an issue for that power level.
Old Jul 19, 2007 | 06:21 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I think you will need some head porting and cams to get the power you are after
Steve.
Old Jul 19, 2007 | 10:37 PM
cosy trav's Avatar
cosy trav
i thought the head might need porting , what cams do you recomend .i was thinking DB14 inlet DB12 exhaust or is this a bit wild or would 12s on inlet and exhaust be better .
Old Jul 19, 2007 | 11:18 PM
abdr500's Avatar
abdr500
bd14 inlet bd10 exshut seems to be a good cam choice for all round power the std ex cam gives less torque i find
Old Jul 20, 2007 | 04:38 PM
cosy trav's Avatar
cosy trav
Thanks for the advice so far people , confusing all the cam choices though . i think im better off talking to stu @ msd as he will be tunning it .
Old Jul 20, 2007 | 04:40 PM
Staffi's Avatar
Staffi
Will a T38 make 470?? how about some 1000cc injectors??
Old Jul 20, 2007 | 05:00 PM
NEIL A's Avatar
NEIL A
Think some T38's will do upto 480 on a bench dyno so should do near 450 in car.
Old Jul 20, 2007 | 05:03 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im sure the TT T38 does
Steve.
Old Jul 20, 2007 | 05:07 PM
OldDan's Avatar
OldDan
Good luck Trav!
Old Jul 20, 2007 | 05:14 PM
cosy trav's Avatar
cosy trav
the TT38 turbo came off a 511 bhp saph , it has had some work done to internals and a turbo technics T4 comp wheel .
hello there dan hows your motor going ?
why you selling the 1000cc inj , was told to grt 850 cc inj
Old Jul 20, 2007 | 05:51 PM
Staffi's Avatar
Staffi
Sorry trav, i meant you get some 1000cc injectors
I'm having a GT30 on mine. L8 1000cc injec..
I have a T38 on now but i find it abit laggy..
Old Jul 20, 2007 | 06:01 PM
cosy trav's Avatar
cosy trav
Lmao thought i found some for sale then .
staffi what cams you got on yours if you dont mind me asking .
Old Jul 20, 2007 | 06:04 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
The TT T38 is surge city and would most likely need live mapping with air injectors to be safe
Old Jul 20, 2007 | 06:09 PM
Staffi's Avatar
Staffi
Trav, they're some of NMS jobs, ..the head work alone was over 2grand..
Old Jul 20, 2007 | 06:35 PM
cosy trav's Avatar
cosy trav
getting it live mapped by stu@msd , heard hes the dogs danglies . will be getting air injectors fitted when i get it mapped .
2 k on head work blimmey . then again when you think about it , cams, double valve springs or solid lifters , pulleys , valves , guides , port and polish soon mounts up .
Old Jul 20, 2007 | 06:40 PM
rapidcossie's Avatar
rapidcossie
I find it hard to believe that a t38 can run 480 bhp never mind 511
Old Jul 20, 2007 | 08:45 PM
Staffi's Avatar
Staffi
My thoughts exactly Euan...
Old Jul 20, 2007 | 11:15 PM
cosy trav's Avatar
cosy trav
this is the turbo ive got . i cant see it making 508 bhp but 470 bhp might be got .
https://passionford.com/forum/viewto...bb029a6285b028
i am going to phone turbo technics to find out about it .
thanks everyone for your input so far it is much appreciated .
Old Jul 21, 2007 | 07:02 AM
Jim Green's Avatar
Jim Green
Universal Turbos version of the T38 will make 440 - 450 absolute max....on a fully worked engine....Head, Cams, Injectors, and all the right ancillaries.
Turbo Technics T38 ..... the most we've seen is on YUM's Engine which again, with all the right bits made 460 + bhp.....I think that's the best we've seen on here from those two turbo's (In the real world), and both engines had absolutely everything....fully worked head, etc.
To get 470bhp plus you need to go to a GT30/T4 or better. And you'll still need all the right bits on the engine.
Old Jul 21, 2007 | 07:28 AM
Staffi's Avatar
Staffi
Exactly, it's a fantastic spec on my saff, credit to Karl & Jim for there work involved, oh and Mike R and Bud-Weis for the suspension..
Will be a very complete car when the GT30 etc are added..
Old Jul 21, 2007 | 07:29 AM
Jim Green's Avatar
Jim Green
Another hard day at the office.....
Staffi : Don't forget LLoyds Bank....
9:30 am here (Palma de Mallorca...Spain).
Old Jul 21, 2007 | 07:31 AM
Staffi's Avatar
Staffi
08.31 Coventry, pissing down..
I've got the bank manager popping round for lunch Jim
Old Jul 21, 2007 | 07:32 AM
Jim Green's Avatar
Jim Green
Get over to Karl's I'm sure he'll have the Coffee on.
Old Jul 21, 2007 | 07:33 AM
Staffi's Avatar
Staffi
1 lump or 2??
Old Jul 21, 2007 | 07:34 AM
Jim Green's Avatar
Jim Green
Bank Manager to Lunch : Excellent Idea......
Old Jul 21, 2007 | 07:37 AM
Staffi's Avatar
Staffi
I'll need around 3k ish i reckon...
Got the Ecu-- already, injec, turbo, 5 bar map sensor, wastegate i'll leave to Karl and then the mapping...2bar+ here i come..
Old Jul 21, 2007 | 07:39 AM
Jim Green's Avatar
Jim Green
A good lunch and a spin in the cossie should cover 3k.
Watch out in the wet though.
Old Jul 21, 2007 | 07:41 AM
Staffi's Avatar
Staffi
A good lunch should cover 3k.
Hope so, if not i'll PM you for a loan Jim....
Right, breakfast for me...
Old Jul 21, 2007 | 07:44 AM
saffsta's Avatar
saffsta
Get a new oil pump
Old Jul 21, 2007 | 01:46 PM
cosy trav's Avatar
cosy trav
already got new oil pump and water pump
ive got 5 months till i get my licencee back so i have plenty of time .
can you get a gt 30 with internal wastegate or is it external ?
i will probably get on if this turbo is to laggy as ive heard there a good unit .
JoeyBoyden
Jan 4, 2024 02:36 PM
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
