My New Engine......Decent spec YB..have a look
Rubber Rhino Crew
Just put my name to this engine, not going to say what I paid but it was a fair price for what it is....rebuilt 3600 miles ago with paperwork to prove, all receipts for work done etc...
CYLINDER HEAD IS GAS FLOWED AND PORTED
DB 10`S
BRONZE VALVE GUIDES PLUS NEW STEM SEALS
3 ANGLED CUT THROATS
MODIFIED INLET MANIFOLD MATCHED TO HEAD
WITH FUEL RAIL INJECTORS
KENT COMPETITION CAM FOLLOWERS
200 BLOCK
SUMP AND CROSS SHAFT
LOW COMP PISTONS
CLEANED AND POLISHED COMBUSTION CAMBERS
UPRATED STAGE 1 FAST ROAD CLUTCH
ENGINE REBUILT WITH GROUP A HEADGASKET AND TIMING BELT
L8 ECU & GOOD CONDITION LOOM + SENSOR PRESENT AND WORKING
What sort of power has this engine been built for do you think? I have a 5-bar map sensor and some 1000cc injectors on their way what kind of power could I acheive realistically with these cams etc.....I know its over 400bhp (which was my ballpark before this came along)...
Place your bets now!
Dan
DB 10`S
200 BLOCK
LOW COMP PISTONS
Dan
Rubber Rhino Crew
undecided as to what im going to use on my setup but engine comes with standrad 4x4 turbo...
I'm after what the lump is upto really with teh cams, followers, pistons etc...turbo can be chosen later after some consultation with my tuner
Any ideas????
Any ideas????
Rubber Rhino Crew
not really mate, if i put a T90 (if there is such a thing) does that make it a 800bhp engine?
So regardless of turbo spec what is the engine capable of is the question im asking...i'm happy with 400bhp so anything else is a bonus really.
Dan
Dan
well your group a head gasket will be the point were most wouldnt push past 400 bhp you will need to be wire rung to be able to use a group a head gasket to beyound 400 bhp with out fail multy layer shim would have been better ...its not a 500 bhp engine
Rubber Rhino Crew
I know its not a 500bhp engine....if its capable of running 400 then i'm happy as I got it (full setup) for a good price.
Dan
Which kind of makes wire ringing them pointless?
I could be wrong though?
