is there a certain primer from celluose?
01-07-2007, 01:42 PM
01-07-2007, 01:47 PM
Live long and prosper!!
Quote:
Originally Posted by jacko
jet black is blue black
Nice one jacko was wondering my self
will have to check with my mate which one he gave me
01-07-2007, 01:51 PM
i can tell from the pic mate yours is a blue black when you mix the paint pull the stick out and look at where it isnt that thik on the stick it should be a bit see through and you can see the blue tint to it
01-07-2007, 03:30 PM
500bhp Cosworth in making
cheers for info mate so jet black is best!
when it comes to spraying my plastic bodykit on xr2 how do i do that
01-07-2007, 04:47 PM
01-07-2007, 05:04 PM
da all the grain off first with 240 go over it with 400 then use plastic adision promotor then primer flat that then paint
01-07-2007, 05:05 PM
while we are on the subject of paint what devilbliss gun do you recomend ?
01-07-2007, 06:57 PM
gti mate great gun but if you can aford it the sata 2000 is far better
01-07-2007, 07:01 PM
jacko have u ever fitted on of these on a xr2 its around passenger suspension turret is it a bastard?
01-07-2007, 07:03 PM
never done one mate but if you can weld you can fit one
01-07-2007, 07:06 PM
have u fitted a front panel before?
01-07-2007, 07:09 PM
they all go on the same mate take the bonet off drill out all the spot welds then off it comes
01-07-2007, 07:10 PM
not a big job then, my local bosyshop reckon it will take 6 hours to take mine off and refit a new one
01-07-2007, 07:38 PM
sould take 4 or there abouts mate but just diy takes longer but if you never do it you will never learn
01-07-2007, 08:20 PM
i done a escort mk4 front panel i drilled the spot welds out on front panel is that right
02-07-2007, 07:53 AM
exactly the same mate just different car if you did the escort you can do any other ford
04-07-2007, 08:32 PM
got my beige hi build primer today and my 400 grit disks
whats best fibreglass filler to use as i have a small hole to fill?
05-07-2007, 06:03 PM
Wilsfoci
15
30-03-2016 10:26 PM
Paul_RS
03-01-2006 12:08 PM
RSBen
19-06-2005 07:52 PM
Adz 131
28-02-2005 11:00 AM
666monkey
02-06-2004 04:48 PM
