car related question quiz time !!!
Old 22-06-2007 | 08:16 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default car related question quiz time !!!
does anyone know why the rubber gaskets like rocker cover gaskets ect all have a metal bead in them to keep there shape ????
what technical reason could there be for this ????
Old 22-06-2007 | 08:34 PM
dave cos4x4's Avatar
dave cos4x4
maybe its to keep them in shape.
Old 22-06-2007 | 08:36 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
and to prevent them from squashing to much when tightened down
Old 22-06-2007 | 08:51 PM
Ginge !'s Avatar
Ginge !
nope all wrong,,,, try again !!!
Old 22-06-2007 | 08:55 PM
AlexF's Avatar
AlexF
to stick the rubber to
Old 22-06-2007 | 08:59 PM
Ginge !'s Avatar
Ginge !
they dont have to have the metal in them,, its there for a PROPER techy reason !!!
i couldnt belive it when i found out
and there all made like that after for a POINTLESS reason of them all looking the same otherwise mechanics would send them back for being the WRONG part
ill tell you why soon though,,,, its soo easy though its pointless but interesting though
but then i also thought the new headgaskets being made from 1 layer of thing steel interesting too son i may not interest you
it shows just how untechy some parts for cars REALLY are though,,, engines are more advanced these days we all know and run hotter we all know but the technology that solving these problems is actually rather basic,,,, so basic that its being over looked too
Old 22-06-2007 | 09:10 PM
dave cos4x4
work is getting to you.
Old 22-06-2007 | 09:14 PM
AlexF's Avatar
AlexF
yeah rubber gaskets are long gone - RTV baby
Old 22-06-2007 | 09:19 PM
Ginge !'s Avatar
Ginge !
ok the answer is ........
they have wire in them as all engines are built buy robots and so they need the wire in them to allow the robot to pick them up and place them on the engine
to keep the shape and for the robot to pick it up magnetically
after that they can be made of just rubber but they discovered that garages was turning them back claiming there the INCORECT part as the one they took off as made of rubber and has a wire bead
yes garages are dumb
interesting yet soooo simple,,,, there is NO other reason for this no matter what you are told,,, this is the ONLY reason for it
imagine a robot picking up a bit of rubber,,, simple isnt it
Old 22-06-2007 | 09:22 PM
dave cos4x4
yes.....
JTECH James
Passion for Fords!
i was thinking of the metal rings around the bolt holes, these prevent squash
Old 22-06-2007 | 09:29 PM
Ginge !'s Avatar
Ginge !
nope, torque settings prevent squash
they prevent the gasket moving though,,, but thats for the robots,,,, the idiots,,,, sorry mechanics also benifit though
did you also know that some engines have suspect designs to them that seem to make them fail at certain milage,,,, renault clio diesel engines are one of them !
the cam pully needs to be changed at 50k miles as theres a "key" that holds the center in place from free wheeling ,,, they made the centers seperate from the rest of the pully,,, when the tooth fails at 50k miles they diesel engine is FOOKED
strange they design it this way though aint it
Old 22-06-2007 | 09:35 PM
JTECH James
Passion for Fords!
no they prevent the gasket squashing cos most non genuine gaskets dont have them, and if you torque them they squash and leak
smitsturbo's Avatar
smitsturbo
is st so the robots can pick them up & put them on engines in the factory?
Old 22-06-2007 | 09:39 PM
abdr500's Avatar
abdr500
JTECHSAFF
i do agree on that but you can still get a good seal if you can evenly tighten up the bolts
Old 22-06-2007 | 09:41 PM
JTECH James
Passion for Fords!
yeah i agree but the cork ones were proper shit!
Old 22-06-2007 | 09:49 PM
Ginge !'s Avatar
Ginge !
the bolts are put in locations so they DO seal around the bolt holes though,,, look at a gasket and you will see that the surface should be flat and as such when the bolts are pinched up at the right torque setting they seal
most headgaskets fail from incorrect fitting
the fire rings on a head gasket should spin free before fitting but when fitted it should be squashed evenly in place,,, thats how it seals by the crush
the gaskets only have 2 jobs,,, to allow for thermal conditions and to make a presure seal
all of them do that,,, most are fitted wrong im afraid to say
theres a few with design issues,,,, some are trying to do a job there no ment to
oh and some people favor gaskets for no reason other than personal choice
the OLD name in gaskets was payen,,,, i STILL get people who wont use anyone else,,, when payen is prob the most outdated and underdeveloped gasket there is in the market
the best is obvious,,, but the other companys now are allowed to copy there designs as there designs to not allow them to be patanted for some reason and i cant remember why
yes they just buy gaskets from main dealers,,, take em to a lab and test them, measure them up and then get the tooling to make me,,, simple,,, then when they fail they rely on there engine building companys feedback and solve the issues from there
Old 22-06-2007 | 09:52 PM
Ginge !'s Avatar
Ginge !
the idea of sealing a engines fluid with old tree bark is someone intersing
it was used as cost fuck all to make the stamp machines,, could be made in there thousends and would soak up the oil and after a year be replaced for a new one to do the same thing
simple aint it
the other issue is that people try to reuse gaskets,,,, never understood that one when you understand what they actually do and how they work
Old 22-06-2007 | 09:58 PM
JTECH James
Passion for Fords!
A.t.p
15-08-2015 11:37 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: car related question quiz time !!!
