help with evo transferbox and propshaft..
hello all, im just stuck trying to get my propshaft out of the transferbox on a evo 3 , ive undone all the 5 x 17mm bolts and MLR say ..
slide off lugs and pop prop shaft out, what is ment by lugs, is it that you pull something back and slide the prop out? any help on this guys
thanks
andy
thanks
andy
Oderint dum metuant
If i remember right, when i did the gearbox on mine, i undid all the transfer box bolts and the prop slid out when i removed the tranny box.......
so much for only crankwalk
was underneath it and the conrods in the middle 2 pots have play from side to side on the crank
what the fooks caused that i realy dont now
but the outer 2 or fine? that must of been the funny bearing noise i herd , i thought it was the thrust bearings, not to sure what to do now
andy
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
andy
