Fitting PC memory.....
Old Jun 17, 2007 | 09:50 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default Fitting PC memory.....
Once you turn the PC off and disconnect the power, is the static or whatever current that remains in the system a problem?
Someone said that you can hold the power button down for 10 seconds to dissipate the static?
What should I do?
Old Jun 17, 2007 | 09:53 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
u've got to touch the inside of the pc....a metal bit....and this earths u out.....u then become a bit one handed.....
Old Jun 17, 2007 | 09:54 AM
Christian and Beccy
#1 in Spelling Club
But does the static dissipate on its own after being turned off for a while? How long? 30 mins??
Old Jun 17, 2007 | 09:55 AM
S1's Avatar
S1
Siwtch off pc, I ususally dont even bother removing power lead but just switch off the switch on the power supply at the back of the case. Touch the case of the PC to ground yourself, pick up stick of memory, put in slot.
That makes it sound like I have thought about it but in reality I just wade in there, done hundreds of memory upgrades in the past couple of years and not fried anything (apart from the one i managed to get in backwards which took out the motherboard in style )
Eagle's Avatar
Eagle
Super Moderator
leave the pc connected to the mains ... if it has a switch on the back of the psu then turn that bit off .. hold onto the chassis of the pc for around 2 minutes as this will normally discharge any major static to earth...
then either disconnect from mains power and plug in memory but hold onto the case with one hand at all times..
not the ideal way of static removal but it does work, and make sure you dont move your feet around too much on the floor as that can build it back up (carpet) ...
not too hard to do with one hand either
Old Jun 17, 2007 | 10:07 AM
FasterFords's Avatar
FasterFords
yep, don't disconect the power lead, just switch off at the mains, the power lead will earth it, so just hold on to the case before starting the job and only pick up the memory from the edges.
Old Jun 17, 2007 | 10:12 AM
Phil's Avatar
Phil
Jeebus
I just shut down pc, open case and bung it in. Done it hundreds of times and never had a problem...
Old Jun 17, 2007 | 10:14 AM
SimonT's Avatar
SimonT
shut the pc down - but leave plugged in as it acts as a earth.
Old Jun 17, 2007 | 10:19 AM
Christian and Beccy
#1 in Spelling Club
OK, I'm off. Back in a while........
MAYBE!!!
Old Jun 17, 2007 | 10:41 AM
BM08's Avatar
BM08
what he said, most of what you read is just cheesey poofs scared there going to break something because of what they read on the internet
Old Jun 17, 2007 | 10:47 AM
Adrian's Avatar
Adrian
Same here and I have done thousands that way. Never had an issue with any.
Old Jun 17, 2007 | 10:56 AM
haz87's Avatar
haz87
And me
Old Jun 17, 2007 | 11:09 AM
Mark_w's Avatar
Mark_w
You have been lucky then as i went to change some ram once and a spark jumped from my hand to the mobo and destroyed the motherboard,which luckily was under warranty...they sell straps on ebay to connect you to the machine,or as said before leave plugged in to earth and before you touch it,go to your airing cupboard and put your hands on a copper pipe.
regards mark
Old Jun 17, 2007 | 11:24 AM
BM08's Avatar
BM08
Mark rs you must have been rubbing a ballon or something prior to installing the ram, thats all i can say
Old Jun 17, 2007 | 11:32 AM
Jim Galbally's Avatar
Jim Galbally
ive taken apart hundreds (or not thousands!) of PCs, never once witha static strap.
i have never damaged one.
the chances are so minimal, its not worth the effort IMHO
Old Jun 17, 2007 | 12:40 PM
TrevCannon's Avatar
TrevCannon
And me
Count me in!
Old Jun 17, 2007 | 12:48 PM
Spiky's Avatar
Spiky
it's mainly down to the fact you earthed yourself when touching the case
ideall straps "should" be used, but touching the case usually a enough
except i "ALWAYS" use a strap when inserting a new blade in a 6500 (cisco equipment) , as they cost 5k-20k a blade and i dont want to blow one
Old Jun 17, 2007 | 02:10 PM
Jamz's Avatar
Jamz
Your PC will be WELL out of date before it dies from static damage so don't worry about it
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
