4x4 rear diff?
Old Jun 7, 2007 | 10:41 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Default 4x4 rear diff?
Disregarding the fitting in beams issue, Can you just stick a 2wd diff onto a 4x4 car, as the ratios are identical at 3.62:1 are they not? , what else would have to be changed? Shafts and stb shafts and rear prop section?
Just wondering if it is worth going 7.5" on the back of my escort as there seems to be more choice for upgrades, or are there decent upgrades around for the 7" jobbie?? Was thinking of a ZF plated or gripper
Old Jun 7, 2007 | 10:47 PM
The DIVA's Avatar
The DIVA
7.5" 2wd cossie beam,shafts,hubs etc all fits straight in.....just stick your vented Escos discs and calipers on.....
Good upgrade,7.5 diffs are stronger and the shafts are bigger...
Old Jun 8, 2007 | 05:42 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
or p.m marco polo and c what he can do with ur 4x4 one
Old Jun 8, 2007 | 06:36 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Default Re: 4x4 rear diff?
don't need to change the prop as it's a direct fit (but they aren't a square bolting so if they don't line up don't sit there moping for 3 days before it dawns on you to try it the other way )
you just need to get rid of about half an inch worth of diff case wehre the bolt goes through and swap the diff, shafts and stub axles into your beam and away you go
Old Jun 8, 2007 | 08:55 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
FYI, there IS a difference, the 2wd is actually 3.64 . However, the difference is so small that it won't cause any problems, so it is a common upgrade to fit the 7.5 diff, but not because the diffs are any stonger, but because of the huge improvement in the CV joint's strength on the drive shafts, due to their meatier size .
Old Jun 8, 2007 | 03:14 PM
RWD_cossie_wil
worth doing then?
Old Jun 8, 2007 | 04:26 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
You could have my Marco modded 7" diff. Will be going on Ebay tonight.
Worked nicely on my 470bhp car. Saves all the above hassle, just bolts in where yours came from.
You can also sell your old one on, or keep it for spares if you wanted.
Link for it will be in Parts for Sale later this eve.
Si
Old Jun 8, 2007 | 04:46 PM
RWD_cossie_wil
what is the spec Sib?
Old Jun 8, 2007 | 04:57 PM
Si B's Avatar
Si B
Marco Mullet 7" Cos 4*4 Rear Diff Spec
3.62 Ratio, fully serviced
1 x New pinion seal
1 x Collapsible Space (fook knows what that is )
1 x 7" Modified and shot peened gears
1 x 7" VC reset to 120NM
Cost me over £600, and I supplied my original diff. Basically for you or anyone else thinking about it, you can sell your original diff for £150 or whatever they're worth, and put it towards the cost of a decent one.
I'd be open to very sensible offers, but if none are forthcoming, it will be on Ebay later tonight (once I get back from a Car Auction)
Also got a "Mulleted" front diff to go to!
Si
FlashRS
Sep 14, 2015 12:36 PM
3drRich
Sep 13, 2015 07:32 PM
mint_s2
Sep 2, 2015 08:58 AM
xr4x4rs
Aug 6, 2015 09:03 PM
