Advice needed on welded diffs please
Old May 29, 2007 | 04:20 PM
se mk3 cabbie's Avatar
se mk3 cabbie
Default Advice needed on welded diffs please
Mate at work is thinking about welding the diff on his mk1 escort, i'm sure i read on here a while ago it was not a good thing to do to a road car but cant remember reason why, any help much appreciated
Thanks
Old May 29, 2007 | 04:23 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
only complete pussys and people who have never tried a car with one seem to say its bad.
ive driven god knows how many cars with them, hell, i currently own 3 cars with them, they fine.
slightly more understeer, shuffling juddering when turning tightly at 5mph or less, and thats all.
the same sorta bad stuff you get with a proper plated race diff, just without the nasty noises as it locks n unlocks etc...
Old May 29, 2007 | 04:28 PM
se mk3 cabbie
Cheers mate, i just remember a thread a while back and people saying it could be dangerous on road for some reason and best left for track use
Old May 29, 2007 | 04:33 PM
xr2i-carl's Avatar
xr2i-carl
it
just
wears
tyres
out
quicker
Old May 29, 2007 | 04:35 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Id not say its dangerous mate, if anything less so as its initially harder to lose traction as its much more grippy and a little more understeery.
If you TRYING to get a car sideways id say its much more controllable than an open diff, much more.
Partly as you got power to both wheels without making a huge effort to do so, and also because with an open diff you can easy smash as one wheel can suddenly grip mid slide, punting you off in the direction your wheels are pointing, ie oppo lock, ie the outside of the bend.
Ive had offs for this reason more then once.
With a welder that doesnt happen, both wheels may grip, but not as suddenly as just one will with open gay diffs.
If you that spaccafied you suddenly crash as you got a welder, you deserve to
He will be fine.
Old May 30, 2007 | 07:43 AM
foreigneRS's Avatar
foreigneRS
Testing the future
agre completely with Stavros, and yes i have had one on the sierra cossie estate in my sig
Old May 30, 2007 | 08:04 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Does welding the make them any stronger? As in a standard 2wd diff asking to cope with 400 bhp. Would welding whatver it is that gets welded help prevent failure?
Old May 30, 2007 | 08:08 AM
GARETH T's Avatar
GARETH T
i agree with steve aswell!
Old May 30, 2007 | 09:05 AM
foreigneRS's Avatar
foreigneRS
Testing the future
absolutely, but depends on diff type.
the small gears inside are what normally break on cossie rear diffs, and these get welded together and plated over making in effect a solid centre with the only points left to break being the crownwheel or pinion
Chas
Sep 21, 2015 08:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
xr4x4rs
Aug 6, 2015 09:03 PM
COLEYST200
Aug 3, 2015 08:55 AM
