fitting longer wheel studs...
Old May 27, 2007 | 12:10 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default fitting longer wheel studs...
fitted up the cossie hubs etc to the 3dr yesterday, and then smashed out the wheel studs to put the longer ones in...
i thought i could just wind a wheel nut on against the hub and it would pull it in...
well, not quite
they go so far in... then wont go in any further lol
so how you get em in?
is a hub off job and a press?
Old May 27, 2007 | 12:20 PM
Fil's Avatar
Fil
ELASTIC BAND
I allways put a few washers over the threads and like you said, nut on and tighten it up, pulling it through.
Never taken a hub off to do it
Old May 27, 2007 | 12:24 PM
GARETH T's Avatar
GARETH T
smash them in with a copper hammer
Old May 27, 2007 | 12:26 PM
dojj's Avatar
dojj
Resident Wrestling Legend
use a spacer
use a steel nut as well as you can reverse it as the flat end will do much more even job of pulling and locking the knurled bit of the stud into place
Old May 27, 2007 | 12:37 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers boys, ill try it with washers when im down the lockup next.
gareth, cant really get a mallet onto them, the only gap is between the lugs of the brake calliper, and you cant get a flat hit on the stud, only the edge
Old May 27, 2007 | 12:40 PM
dojj's Avatar
dojj
sod putting washer in then
put the studs in as far as you can go
the bit at the end you can't get tightened enough you just put the brake dics on and use that
GARETH T's Avatar
GARETH T
sorry i thought the hub was off
i wound mine in when they was fitted to the car though
Old May 27, 2007 | 12:42 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers G
Dojj, there is no shank bit to the stud, it just wouldnt do up any tighter, but ill have another go with washers on
Old May 27, 2007 | 12:50 PM
Fil's Avatar
Fil
ELASTIC BAND
ive used the washers to spread the load, and pull it through nicely.
note : im not talking about using washers behind the hub, just to spread the load , they are removed once the studs 100% home.
Old May 27, 2007 | 04:59 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Old May 27, 2007 | 07:30 PM
NUTS RuS's Avatar
NUTS RuS
2 nuts will also do it
Old May 27, 2007 | 07:50 PM
dojj's Avatar
dojj
Originally Posted by Dan@FastFord
cheers G
are you doing it the way in the diagram shows?
if so, you just use the disc instead of the washers
Old May 27, 2007 | 08:03 PM
Alvyn's Avatar
Alvyn
do the new studs have the RIGHT amount of splines for the hub? IF so they should just pull tight with ease!
Old May 27, 2007 | 10:13 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Alvyn
dunno, could be why it tights as fook then lol
Old May 28, 2007 | 07:22 AM
Some studs have a very slight angle to the splines so make sure they are lined up ie spline in between spline etc, had this recently on a honda(yank), though he was quoted two hours labour to remove hub etc, did it in 5 minutes no hub off!!
Old May 28, 2007 | 07:14 PM
dojj's Avatar
dojj
they can be pulled out with just as much ease then
they need to go in tight as fuck as they stop the wheel nuts from spinning when you try to undo them
if they are the wrong ones you are fucked come this time if this happens
did you get them from speedshack? he sells them for the sierra and they slot right into place
(other suppliers do exsit)
Old May 28, 2007 | 08:13 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
they came with the Eiback 20mm spacers lol
the rear 30mm spacers are hubcentric and bolt to the hub, then whell then bolts to the spacer
Old May 31, 2007 | 05:43 PM
Alvyn's Avatar
Alvyn
Dan, how'd you get on?
Old Jun 1, 2007 | 09:59 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
not been back down yet mate, ill hopefully get over tomoz.
(the car is a 70 mile round trip fomr my house, not in the garage unfortunatly )
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
cossynut2
Aug 19, 2015 11:29 AM
IAN RS2k
Aug 18, 2015 07:51 PM
markk
18
Aug 17, 2015 05:19 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
