coilovers again
Caraholic
Seriously, save your pennies and put the additional money up for the gold kit, or some proper ones £800-£1,000 - I can PROMISE you, it will be the best EXTRA money you have spent, or you will kick yourself when the cheap ones adjusters sieze up / you get pissed off with the ride quality going down the pan.
I have to agree with Mike tho ,,its always better to buy the best you can afford
Easy if your as rich as him tho
The GAZ £500 still come with 2 year warentee. I have never had one seize up, either height wize- as the threads on the bodies are corse unlike the fine threads of others. The bodies are zinc plated, illiminating corrosion and the dampening adjusters are a ball bearing type, designed not to seize. The main reason to buy the GAZ Golds, is the greater range of adjustment to suit track, road and race.
Caraholic
The GOLD adjusters are mearly fitted with a larger knob. I know for you it would be exciting to be able to play with a larger knob, but most of us can do that all the time.
You get what you pay for I guess, but unless you have an unlimited budget, there are loads of other things that need to be bought too. If money was no object, it would be different...hard for you to understand eh?
Caraholic
It's just that I have HAD the cheap budget coil-overs as well as the expensive ones, and I can say with my hand on my heart that spending the extra to get the better ones is 100% worth it, and buying the cheap ones is a completely FALSE economy .
However, I can clearly see that it is the case of the age old adage - "you can lead a horse to water...." .
Originally Posted by BROM@ZOO
i rember one thing about the old avo the fuking plastic grub screw for the ajuster i hope to got they dont fit these anymore and use to lock rings instead of the screw
i really dont know what to do
will be getting a zoo rear beam at some point later this year
and big brakes before i try and extract more power
but suspension is a must just now
what other options have i got to get the rear end siting higher and not squating as much
Originally Posted by tabetha
My ones had plastic grub screws as well, just put a metal one in instead, can't see why they put plaggy ones in!!
Have you never had an alloy wheel sieze itself onto a metal hub as surface corrosion occurs on both?
Imagine that on a tiny screw lol, when it comes to service time you would never be able to remove it.
What we do is put a tiny plastic crush bead in under the grub screw to form a barrier between the two but still allow grip.
Most decent coilovers dont have lock rings any more. There is a reason but I wont bore you
Open or corse threaded ones are never going to be as good as a clean fine threaded one, just grab the spring platfom and move it about to see how much rattle play it has in it
As for adjustability, I think I have lost count of the number of people I have seen parked up on the M5 adjusting there settings because there is a bend coming up
Most people will play with the settings in the first week or month or so, then when they get bored of crawling about underneath they will never ever touch it again so who cares if they sieze up lol as they wont
Buy the best you can afford if you want them to work well, and continue to work well
Caraholic
LEDAs are no longer available, having gone bust, but a couple of the bods from the technical dept have left and started up on their own, so you can get something similar (but improved, as they now fit high speed valves after speaking to customers and finding out how they could improve upon them).
I really like my LEDAs and have had no problems with them in four years of being on the car!
i do no why they dnt av 2 rings but i just keep um clean
do you think my money would be better spent on these than cheap coilovers mike
I now need to have a look at the handling of the car now as the back is too stiff compared to the front and it oversteers on slow bends..
Caraholic
no mate i think i dint make my self clear as usaual
you said most decent set ups dont have 2 rings
all i ment was sean had 10k worth olins and they had 2 rings on no grub screw
Not had a proper chance to mess with it yet..
