FAO plumbers or builders
0-60 in 17 seconds (eek)
I am in the process of replacing the water mains feed to the house (between stop-cock and raising main).
I've got some 25mm MDPE (sp?) pipe and was wondering what I should use to insulate and protect it.
It will be 80 cm under-ground as required by the local water authority, but I was wondering if I needed to protect it with something under-ground, and, insulate it further with some sort of lagging / foam pipe insulation, etc...
Can't seem to find anything that will fit 25mm pipe![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Thanks in advance
Greg
Thanks in advance
Greg
Football Cwazy
it should be fine left unprotected at that depth....be careful what you use to backfill though, sharp stones will knacker the pipe, and you don't really want much ground movement near the joints.
Have you asked the water company to pay towards the cost of the relay by the way? there's a chance they might
Have you asked the water company to pay towards the cost of the relay by the way? there's a chance they might![Top](https://passionford.com/forum/images/smilies/smile011.gif)
What do you mean by "cost of the relay" ? They have already replaced the stop cock with a modern one free of charge when we asked them to check our water pressure/flow, so I'll be linking the new pipe straight into that.
Guest
Posts: n/a
Sounds like you're tackling something that I could do with.
Have you had them out to check the pressure cause its rubbish? I did the same and they told me to do what you're doing as its the ancient pipework and shared supply thats probably causing it, suggested I lay the pipe and have my own supply, but I dont fancy/cant be arsed doing it.
Football Cwazy
Fixing these leaks is a ballache because of all of the hassles involved in actually finding the leak to start with, and then making a tidy job of it on someones driveway or garden causing grief. So basically if you told them you have a leak and are willing to replace your own pipework, they may foot some of the bill.
Also if the pipe you are replacing is lead, then they will more than likely help out.....although i can't be sure because it probably depends on the water company.
They told us everything was fine on the supply side (which isn't shared btw, we have our own stop cock), but while pressure was good in the house, there was very little flow...
If you've got a shared supply, you'll probably need to talk to neighbours/water board since any work you do will affect them
Pics below to give you an idea of the work I've done (all by hand btw
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Haven't got pics of the kitchen where the supply arrives yet either... kitchen units out, floorboards up, you name it...
![](https://img.photobucket.com/albums/v129/frog1/home/WaterSupply/DSCN0270.jpg)
![](https://img.photobucket.com/albums/v129/frog1/home/WaterSupply/DSCN0271.jpg)
![](https://img.photobucket.com/albums/v129/frog1/home/WaterSupply/DSCN0272.jpg)
![](https://img.photobucket.com/albums/v129/frog1/home/WaterSupply/DSCN0273.jpg)
![](https://img.photobucket.com/albums/v129/frog1/home/WaterSupply/DSCN0277.jpg)
![](https://img.photobucket.com/albums/v129/frog1/home/WaterSupply/DSCN0278.jpg)
![](https://img.photobucket.com/albums/v129/frog1/home/WaterSupply/DSCN0279.jpg)
![](https://img.photobucket.com/albums/v129/frog1/home/WaterSupply/DSCN0280.jpg)
Oh well, I've done most of the work without needing to buy/hire anything so it hasn't cost me much so far except time, sweat and fat (that I've lost
I don't really want to go digging again just because a sharp stone decided to make its way through the pipe
Football Cwazy
Not necessarily no, but it may be worth buying some shingle that's abit less sharp to avoid it, the trouble with doing that is if there is ever a leak the water won't necessarily come up at the point of the leak, it'll run down the conduit to the easiest exit route, so will take ages to find it. (most leaks don't show at the surface anyway.)
the pipe is fairly tough to be honest..
Another tip : tape a strip of metal to the length of the pipe...that way if you ever sell the house and there's a leak, the pipe will be easier to trace for the new owners/water board.
can't see the pics at work i'm afraid
i'll look later on at home
i'll look later on at home ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
I was thinking about leaks and the pipe, as you said, it may not be the best idea.
How about wrapping it in the grey insulation foam you find on most hot or air-con pipes ? I guess that could introduce similar problems with leak diagnosis
After seeing your pics I can without doubt say I wont be attempting that
far to much work involved for my liking, I'll grin and bare the crap pressure![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Football Cwazy
The material you've excavated doesn't look too bad, but i'd still put a layer of sand or summat down first immediately on top of the pipe, maybe with some shingle from B&Q or summat, just to help protect the pipe when you start to compress the backfill onto it.
in all honesty your idea about some insulation foam is good, the MDPE pipe very rarely bursts at the sort of pressures you see at domestic properties, the boundary box you now have fitted in place of the stop cock should be good for around 100 m/h (10bar ish) and the pipe will take more...but i bet you only have a max of about 4bar anyway.
the weak points are always the joints, so if you have one long piece end to end then your only weak point is where it joins the boundary box and where it enters your property and connects to existing pipework....so i reckon some insulating foam and the material you have to chuck back on will be more than enough
Thanks Marting ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
I'll get a few bags of shingles, and some insulating pipe then, take a big breath, remove the old pipe and put the new one in
Wish me luck
Wish me luck
Disabled Account
14-06-2005 06:17 PM
61
24-03-2005 09:11 AM
