Crank case vacuum pumps on a YB - Technical discussion
Originally Posted by Dan@FastFord
not being thick here - i just dont know lol
what does a vac pump do?
suck the crank pressures out the block etc and back into the inlet or something?
(although is what manufacturers HAVE to do as they arent allowed to dump it on the floor, lol)
Originally Posted by GARETH T
i think it would increase blowby as there would be a higher pressure differential
Originally Posted by Stavros
Seen one on a foriegn Supra once, if they were to be belived they gained a suprisingly silly amount, over 30horse or summat.
Cant remember the details now
In my mind, if it gains you 5bhp for basically bugger all effort and bugger all expenditure (second hand pump) then it seems like a very worthwhile modification.
Might cure my valve stem seal smoke as well
Will increase power due to less drag on crank...BUT positive crankcase pressure primes the pump and helps to ensure a steady flow of oil into the pickup...when you dabble with the vacuum pumps there is less pressure to push the oil thru the pickup.
Ie you are basically removing the same pressure from both sides of the oil system.
DEYTUKURJERBS
Some testing, albeit on Hondas, here...
http://www.honda-tech.com/zerothread/1199935
What about an oil accumilator?...a sealed cylinder with a floating piston. Pressurized air on one side of the piston forces a reserve supply of oil into the engine if the flow from the internal oil pump is interrupted...this apparently works better than your idea Chip on a wet setup.
Oil pump is easily solved Phil TBH, just go dry sump, which is better than any alternative that im aware of and solves many other problems too such as surge.
But like I said, im not actually convinced that reducing crank case pressures will have a significant effect on the pump for the reason I mentioned about it taking pressure from both sides of the oil system.
Interesting reading, the upside of the exhaust ones is that they dont ever create too much vacuum, but if I used an electric pump I would monitor the case pressure anyway and only turn the pump on in circumstances where it was acceptable to do so.
....you have to bare in mind 2 years ago i had no idea it was a dry sump setup..even though it has a seperate tank in the engine bay with a dipstick ...it was a dizzy Mike R moment
..you ever get a feeling that you have to watch what you say cause haters are everywhere?
Looks to me like an neat an simple solution, i'd certainly give one a go...
http://www.accusump.com/
And I defo dont hate you phil, you lush handsome B**tard
So, anyway, moving away from Phil and his usual off topic crap, and back onto the subject at hand....................
Seems to me you are always looking for a scape goat when YOU start on me..get over it and chill.
Just stay on topic or butt out please Phil.
DixieTheKid
11
06-06-2020 11:20 AM
wheelwizardrefurbs
24-09-2015 08:35 PM
