18's on 3 doors
Old 14-05-2007, 09:37 PM
Alps Pacino
Alps Pacino's Avatar
Default 18's on 3 doors
Before i start i wouldnt mind input from those people who actually have 18's on a 3 door and not people who thnk they know.
So does it fuck the car up handling wise on a road car/
Do they catch like fuck?
Do you need the ride height of a toyota hilux to fit them?
Cheers in advance gents
Old 14-05-2007, 10:00 PM
Eagle
Super Moderator
PassionFord Gold Member (Male)
Super Moderator
Eagle's Avatar
bruce read had em on hs 3 door and rs500.
you need to seriously attack the body kit,
they do not make the ride shit,
his was around 1 inch lower if i remember.
Old 14-05-2007, 10:04 PM
Alps Pacino
Eagle
I pm'd martoon and he said bruces car handled and rode well. I didnt start this thread cause i doubt martin its just bruces car was a track tool and not a road car iirc ?
The arch's on mine have already been chopped up a bit but nothing mega
Old 14-05-2007, 10:07 PM
c9sse
c9sse's Avatar
you notice to lorry tram lines alot more this can pull you across the road but if you could put up with that no other difference.
you need to cut the arch and kit right back on the front then have your kit glued back on and fit 35 profile tyres.
Old 14-05-2007, 10:10 PM
Alps Pacino
c9sse
I dont realy want to butcher fuck out of the car tbh. The problem is i like the cxt's but they only come in an 18 which helps me no end
Old 14-05-2007, 10:11 PM
c9sse
c9sse's Avatar
this runs gaz coilover with 18x8 mo's
Old 14-05-2007, 10:15 PM
c9sse
c9sse's Avatar
believe it or not done properly it wont look that bad,the arch is covered over by the kit and the kit just needs to be trimed and smoothen on the inside lip.
Old 14-05-2007, 10:26 PM
smitsturbo
smitsturbo's Avatar
how sexy does that look tho
Alps Pacino
no offence but that just looks far to pimp for me, its on its fucking arse. I'd prefer to look at some differnt wheels if 17's are a better option over the 18's tbh. cause i fucking hate wheels that rub its proper chavtastic lol
Old 14-05-2007, 10:34 PM
bud-weis
Football Cwazy
bud-weis's Avatar
i defo think you can acheive a nicer look with a 17" rim with a better offset on the back than what you normally see.
there is bound to be wheels out there that look similar to the comps too ( venoms? lol )
get summat with a nice dished rim maybe?
Old 14-05-2007, 10:40 PM
Alps Pacino
bud-weis
What i really want is a set of the 3 piece splitties that compomotive do but i would rather buy some cheaper wheels and buy a t4 and go for more power lol. I just cant fucking decide EVERY 3 door you see has compomotive mo's either in 5 spoke or 6 spoke form. I was considering hocks but i just dont know. I want something that ant the same as every other cunt thats why i thought cxt's
Old 15-05-2007, 06:01 AM
Eagle
Super Moderator
Super Moderator
Eagle's Avatar
split rims are the way forward
agree wit the tram lining tho, but then thats the same for any 18 inch wheel i seriously found my saff improved handling wise on the road when i changed from 17's to 18's..
and i can say bruce used it just as abusive on the road
front wheel arch is a bastard to do, the lower you go the more you need to remove
Old 15-05-2007, 06:34 AM
jasonp
jasonp's Avatar
I had 18's opn ym old RS500 and it drove totally fine, to behonest it felt better than with the standard wheels. Mine was running on coilovers as i couldnt get the height right with springs.
Old 15-05-2007, 09:48 AM
neilm
neilm's Avatar
I owned the car after Jason and did convert the fronts back to Konis and then ran Ahmed springs on it and there wasnt a problem.
There had been some minor mods to the body kit to get the wheels on without rubbing.
Fronts were 17" with a 40 profile tyre, rears were 18 with a 35 profile tyre and the spare was a 17" with a non directional 40 profile so it could go on any corner.
The only problem I had with the set up while I owned the car was the Hocks were made of marzipan and running the 18s with a 35 profile tyre meant they were prone to pothole damage and I had to have one repaired by Pristine Wheels over in Woburn Sands.
And at the time the 18" tyres were dear but they've come down loads since then.
Old 15-05-2007, 09:50 AM
Ryan
Ryan's Avatar
18 generally go on 3dr's without too much drama as many have such a pony offset that they sit in about 2 inches from the Arch.
18's go on fairly easily if the car isnt lowered like a pimp mobile, which IMO ruins the handling anyway.
Old 15-05-2007, 11:09 AM
Alps Pacino
Ryan
So you reco 18's with minimal arch work is no bother. What width though, offset and tyre size???????????????
Old 15-05-2007, 11:19 AM
Ryan
Ryan's Avatar
apls, if u look at the 500 above jason/neils, u will see the height that the rear sits at on 18's, personally its almost perfect height for me, maybe a little lower, say 10-15mm, but i bet minimal kit work was needed to achieve this.
To fit mine however with my offset and tyre size i needed loads of arch work.
I reckon your usual size and offset will be fine i.e 25/35 and 18x8, tyres probably 225/35/18
Old 15-05-2007, 11:23 AM
Alps Pacino
mine is on coilovers so could adjust to suit, however i dont fancy turnng my car into a range rover just so i can have some cxt's
Old 15-05-2007, 11:25 AM
rsnissan
rsnissan's Avatar
What are people bonding the kit back on with once cut?? stikoflex or something else?
Old 15-05-2007, 12:15 PM
Ryan
Ryan's Avatar
3m double sided foam tape same as original.
Old 15-05-2007, 06:05 PM
jacko
jacko's Avatar
mine had escort cos ofset on them the arches where choped right back and the front bumper was moved forword a bit i personaly wouldnt chop the arches on a 3 door as it can help it to rust
Old 15-05-2007, 06:08 PM
Alps Pacino
jacko
And we all know that sierras need no help in rusting
Old 15-05-2007, 06:39 PM
cossie350
cossie350's Avatar
Ride and handling is fine, ive had to do the mods to the arches mentioned above. Couldnt go any lower than in the pic with out it catching on bumps as the offset makes the wheels stick out more than Marks 3dr above with the gold mo's.
Old 15-05-2007, 06:40 PM
jacko
jacko's Avatar
oh and it tramlined like fuck but it might not have been set up right it had 8.5 x 18s
Old 15-05-2007, 06:44 PM
Alps Pacino
i've found 2 sets of 17's now a set of rl7's and a set of th's
The rl7's are 8x17 and et33
the th's are 8x17 and et28
I'm guessing these will be suitable for a 3 door
Old 15-05-2007, 06:55 PM
jacko
jacko's Avatar
it sat realy nice at this hight on these wheels
Old 15-05-2007, 07:11 PM
cossie350
cossie350's Avatar
Old 15-05-2007, 07:19 PM
GUZZLER
GUZZLER's Avatar
Sassy's 3 door had 18 inch comps, et35 with 225/35-18's, ride height was nice & it had no arch mods as far as i was aware, it used scuff on the rear tyres sometimes, only if being driven very hard or if the kids & a load shopping was in the back
i'll try & find a pic a bit later.
Old 23-05-2007, 12:07 AM
boXXer
GASH!
boXXer's Avatar
im possibly looking for some 18's on my cos. Dunno what to do yet.
Old 23-05-2007, 09:00 AM
Porkie
Porkie's Avatar
Arches all cut right back and welded up though so no chance of rubbing...
ride unaffected really.
Old 23-05-2007, 09:24 AM
boXXer
GASH!
boXXer's Avatar
what do you have to weld then? i thought it was just the lip on the wing that got in the way?
Old 23-05-2007, 09:33 AM
Porkie
Porkie's Avatar
Old 23-05-2007, 11:20 AM
boXXer
GASH!
boXXer's Avatar
ahhhh.... no arch at all left then, lol
chowfornow
14
05-01-2019 09:01 PM
07-10-2015 12:56 PM
mpilk
27-09-2015 09:21 AM
Vacuman
22-09-2015 12:09 PM
Vincereese
18-09-2015 12:48 PM
Quick Reply: 18's on 3 doors
