T34 or bigger?
RWD Racer
Atm I only use my escort for track use, so I'm thinking would it gain from a turbo change?
The mota is stock apart from being stg3 n it runs a T34 with a .48 exhaust housing that regularly runs the limiter in all gears.
If I were to go to a .64 exhaust housing would there be any real noticeable difference in punch given the car is more or less always driven in the power band? Or would I be better going to the next size up turbo whatever that may be?
Boost Builder
.63 may be arse coming outta bends and getting it on boost tbh but i aint done a trackday yet so dont quote me on that,.48 will come in quick,maybe too quick and break traction, its swings and roundabouts id say
different intercoolers and different setups will make the boost curves different m8
some will come on early and some will come in late, mine was a hybrid so it does help bringing in in earlier
Originally Posted by b19bal
i wanna be able to come on boost with no fishtailing ![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
It just so happens I have a 2.0 dohc glxi, that I would be willing to do you a straight swap with (it's actually twin engined atm, as it has me cossie engine sat in the boot )
RWD Racer
Atm I have mine set on what I thought was the safe side @ 25 max n dropping back to low 20s.
Room for improvement maybe before a larger turbo is needed then
How do I get the boost to hold @ 25 without dropping back?
![Mmmh (I have an idea)](https://passionford.com/forum/images/smilies/1053181870.gif)
as said in another post, big empty carpark is what u want, did this the day i bought my first cossie, went found a nice bit of empty space and found out how the car handles, etc and most impoertantly how to donut it and do firgure of eights
then after about an hour of fuckin about it was time for roundabouts and nice corners.
Don't take long and once you get a feel for it, you will know when and when not to floor it into a corner or even in a straight line.
impreza wrx sti version 8
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Russ Payne
25-09-2015 08:29 PM
