Cutting -10 Quip????
Old 22-04-2007, 06:20 PM
Rolls
Rolls's Avatar
Default Cutting -10 Quip????
Hi,
Has anyone got any particular tips on the best method of cutting larger quip hose?
I've cut -4, -6 and -8 fine with a grinder, and a cutting wheel, but it doesn't want to touch -10 without making it look like a shonkey shitty mess!
I'm guessing I'll be best of hiring a cut off saw to make the cuts, unless anyone has got any other ideas? - A fine tooth hacksaw seems to want to chew the quip up too
Cheers for the help.
Rich
Old 22-04-2007, 06:22 PM
GARETH T
GARETH T's Avatar
are you taping around your cut?
Old 22-04-2007, 06:23 PM
Rolls
Rolls's Avatar
Yeah - same as per all of the smaller sizes
Old 22-04-2007, 06:34 PM
Retro Al
RWD IS KING
Retro Al's Avatar
try a dremal with a very fine cutting disc
Old 22-04-2007, 06:59 PM
M K
M K's Avatar
hacksaw has always been fine for me
Old 22-04-2007, 07:08 PM
St3V3_C
St3V3_C's Avatar
Will this work?
http://www.justoffbase.co.uk/250mm-C...&category=1051
Old 22-04-2007, 07:12 PM
RichardPON
RichardPON's Avatar
Tape it up tight, and an angle grinder, hacksaw etc should go through no probs.
Old 22-04-2007, 07:20 PM
M K
M K's Avatar
Originally Posted by St3V3_C
£151
Old 22-04-2007, 07:41 PM
St3V3_C
St3V3_C's Avatar
£151
Yea I thought that
Beg / borrow / steal something similar might be an optione though?
Old 22-04-2007, 07:46 PM
pig
pig's Avatar
wrap masking or insulating tape around it m8 and a grinder with a cutting blade in it buddy .hth
Old 23-04-2007, 07:46 AM
Rolls
Rolls's Avatar
Ritey then, i'll have another go tonight then....
I've been trying to cut the -10 in exactly the same way as per all of the smaller sizes though - basically tape around the quip with masking tape twice, and then straight through with a metal cutting disc in a grinder..
Is there another type of cutting disc that is preferable when cutting quip rather than just a normal metal cutting disc?
Also, when using a hacksaw I'd have though that 24 TPI would be fine enough - or is it not?
Its not the actual cutting thats the problem, it preventing the bloody stuff flaring out so much that you can't get the female part of the quip fittings over the end!
Old 23-04-2007, 08:06 AM
philc
philc's Avatar
you can get the really thin cutting dics only a couple of mm thick. They may be better?
Old 23-04-2007, 08:14 AM
ian sibbert
ian sibbert's Avatar
We use insulation tape and a fine toothed hack saw...never had a problem......the disc cutting blades mentioned, that are very thin are for use with stainless steel and only about 2 - 3 mm thick......
Old 23-04-2007, 11:32 AM
THE RADMAN
THE RADMAN's Avatar
i always use my big tin snips,wrap the end first then snip it,it squashes the pipe a bit but its easily put back to round
Old 23-04-2007, 11:33 AM
kevmk2
kevmk2's Avatar
I put masking tape around the end where you want to cut,clamp the hose in the vice and use one of those very thin cutting discs on the angle grinder
Old 23-04-2007, 11:52 AM
magic randy
magic randy's Avatar
ive got some 1mm and 1.5mm slitting discs for my angle grinder.
not tried it on braided hose but im sure its your best bet
about £1.50each tho and they dont last long
Old 23-04-2007, 12:25 PM
Rolls
Rolls's Avatar
cheers for all the help guys - a trip to B&Q / Halfords is in order when I get home from work..
Old 23-04-2007, 05:17 PM
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
I wrap the hose in tape then use a hammer and sharp chisel to cut it, normally have to hit it 3/4 times - works very well.
goodluck
Old 23-04-2007, 05:35 PM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
use the angle grinder and thin cutting disc,but go round the hose 7 times very tightly.when cut unwind the tape till only 2 left,if it still wont fit use a jubilee clip to compress the end of the hose.ive done -16 this way and it works very well
Old 23-04-2007, 07:46 PM
Rolls
Rolls's Avatar
Well - update time
Went to halfords and Band Q and they didn't have any dremel tools or thin grinder discs that were suitable....
So..... Of we came home, and thought i'd give it one more go...
Wrapped the quip up what seemed like 6 or 7 times, and cut through it a quater at a time with the grinder... - much neater, and it just about fitted into the fitting - was then a case of westling with the male part of the fitting to get it to match up - but it did, and its now assembled!
As for the below - I didn't think of using a jubilie clip to compress it slightly, but will do on the next one I do - I think it will make life a fair bit eaiser! - cheers for the tip!
timsrs
13-11-2018 11:48 AM
155lee
27-10-2015 04:55 AM
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
Quick Reply: Cutting -10 Quip????
