Put a 4x4 crossmember and steering rack into a 3dr
just put the crossmember and steering column in my 3dr and the fooking two are miles apart i.e the steering coupling and bush are way too short.
is a 4x4 steering column longer? so it protrudes more in the engine bay?
2Evos & 1 Escort Van :-)
Originally Posted by SiB
Think you need a 4x4 steering colum to rack link/ knuckle thingy...
I've got one here I can measure to see if it's the length you need?
Si
Si
Just measured it and it's 375mm long laid flat end to end.
Hope that helps diagnose what bit's needed - I got mine from a dead XR4x4, for £10 after my turbo melted the bush in my last one.
Si
Resident Wrestling Legend
hope you've got different engine mounts too, as they are different as well
but yes, the intermidiate shaft is longer as the rack sits in a different place so your geometry might be out as well
if you are mising the shaft then you'll need to fork out £108 for one from fords as they are 4wd specific
ahh right so i need a 4x4 steering knuckle coupling thingy.
least thats easily sorted.
next question, anyone got one going spare
and for the record, im only putting 4x4 stuff on as thats all that was available to me, i dont want to put my Ford 909 stuff on purely for it to go up fords and get fucked
hi jase, there was only the little coupling left on the rack, not the hole unit, i.e it was the clamping section, i have 2 2wd ones here and they come up about 50-60mm short
also need some castle nuts for the rod ends if u have any? i havent got any from what i can find, might have to check my other garage tommorrow.
cheers for those bits i'll have to drop them back to you mate
what does that mean ?
Sod buying a new one from Ford
Si
si, yes it would be just a temporary measure no more than like 2-3 weeks if u can spare it that long?
if not i'll phone some traders today to see if i can get one
escort mk4 cossy 4x4
dont know if this helps but the steering columb on my saff 4x4 is adjustable in length.the bottom part that is triangular fits into the rest of the columb via a white plastic bush.use a pair of molegrips and a hammer and it will pull out.
Originally Posted by dojj
wouldn't be doing that "adjusting" thing if i were you mate, it's all to do with torsional rigidity in the shaft or soemthing when you turn it and the plastic is there to help eliminate the need for a whole shaft if one bit stops working
0-60 in 17 seconds (eek)
Probably also plays a safety element in case of a crash, where the column is allowed to collapse, rather than the steering wheel shooting up into your face. I am not sure I'd tinker with it [/quote] so making it longer would make if safer,extra 60mm to colapse before it caves ya head in.
there is a colapsable section in the top part of the rack where it bolts to the bulkhead, just behind the actual steering portion of the shaft once you've cleared the space for the stalks
on loads of cars you will see in the scrap yards, this section is compacted ut it hsould be twice as long as it is
i've got a pic somewhere showing what i mean so i'll look it up
you can JUST about make it out under the foam but there is a corugated section of metal tube which compresses under impact, much like an evian bottle that you can squash when you are finished with it
and another little story for you:
i've got the shaft that ryans been after, wrapped it up (as anyone who has had a parcel from me will testify, i do tend to make they a little over taped ) and then went to post it
now, this shaft is probably about 15 - 18 inches long and, covered in black duct tape, it could be said to resemble a sawn off
so, i'm walking down the road with it merrly dangling from my hand and these little school kids came in my way and said "where you going?"
now, these little ruffians wern't about to stop me going to the post office so i did a little double take just to be sure they were on the level
"you what?"
"you heard me, where are you going?"
"i'm going to knock you the fuck out if you don't get out of my way" and raised the steering shaft
backing away he said "no, really, where are you going?"
"to the post office, where are you going?"
"to call the police"
and then he ran away
i must admit, i did look a bit gangsta strolling down the road with the duct taped steering shaft in my hand also scared the cashier at the post office as wll when i dropped it on the counter and said "can i borrow some selotape please" if i've had said "give me all your money" she probably would have as well
Good old PF peeps to the rescue
borboyous
22-08-2015 11:17 AM
kyle_st200
Ford Focus Diesel
21-08-2015 09:28 PM
