cambelts, whats the tensioner? does it always get replaced?
Old 19-04-2007, 02:32 PM
Cawood
Cawood's Avatar
Default cambelts, whats the tensioner? does it always get replaced?
when changing the cambelt, whats the tensioner
i guessing its something to do with adjust the tension of them cambelt? involved with setting it up?
do you always replace these when doing the cambelts? do they have to be replaced everytime?
i dont understand it fully, can anyone shed a bit of light?
cheers and yes i know im stupid
Old 19-04-2007, 02:39 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
You don't have to replace the tensioner
Steve.
Old 19-04-2007, 02:43 PM
Daveyboy
Daveyboy's Avatar
but its advisable to.....
Old 19-04-2007, 02:46 PM
Rolls
Rolls's Avatar
Yeah, for the sake of 30 quid for a new tensioner and bolt i would replace it too
Old 19-04-2007, 02:48 PM
mark_24v_wiring
mark_24v_wiring's Avatar
Steve.
You do if its a zetec engine its storngly advised to change tensioner and idle pullys
So i guess it would depend on what engine were talking about
Old 19-04-2007, 03:07 PM
Cawood
Cawood's Avatar
cheers lads but more trying to find out what it does n stuff rather than should i replace it or not (im replacing it anyway)
just wondered, just trying to understand what it does and why it should be replaced?
Old 19-04-2007, 03:16 PM
bud-weis
Football Cwazy
bud-weis's Avatar
basically it's there to keep the cam belt at the correct tension, it bolts to the cylinder head and then once the cam belt is fitted it is adjusted outwards against the belt to increase the tension.
it needs replacing because it runs on a bearing and there's a fair bit of stress on them, the bearings wear with age and can basically break or loose tension fucking your cam belt/head/engine.
Old 19-04-2007, 03:34 PM
Cawood
Cawood's Avatar
bang on, cheers martin. i understand that
Old 19-04-2007, 03:46 PM
RichieST
RichieST's Avatar
i've heard of more cars with tensioner failure than cambelt failiure, so yes, you would be stupid not to change the tensioner and any idler pulleys when doing the cambelt just for the sake of a few extra quid
Old 19-04-2007, 04:21 PM
Deleted by Request
Former Sponsor
Deleted by Request's Avatar
....all you need to do is spin the tensioner if it runs nice and smooth and silent its ok..if not replace.
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Quick Reply: cambelts, whats the tensioner? does it always get replaced?
