ecu swap on cossie
18-04-2007, 06:23 PM
ecu swap on cossie
whats needed to swap the l6 ecu from a 2wd saph to the later l8 from the 4x4 ?? and how easy is it to do ?
any help appricated
18-04-2007, 06:25 PM
correct chip for spec your running,4x4 tps will need to be fitted and DONT forget to change the 2 outer wires that go to it!
18-04-2007, 07:09 PM
as above piece of piss
19-04-2007, 03:00 PM
when you say outer wires do you men the ones on the multi plug ?
19-04-2007, 03:31 PM
More boost Igor!
Quote:
Yes, or can be done at the ECU multiplug
19-04-2007, 04:00 PM
any one got the pin numbers that need to swaped
19-04-2007, 04:08 PM
30 and 11
not easy doing it at the ECU, much easier on the TPS plug
19-04-2007, 04:11 PM
i see now swap on the tps plug not at the ecu end
19-04-2007, 05:36 PM
You will find the differance in running like chalk and cheese m8, a worth will upgrade i think all will agree
Steve.
19-04-2007, 06:32 PM
well thought as my ecu has just about give up i may as well upgrade as i go
DixieTheKid
11
06-06-2020 11:20 AM
R4N SS
Ford XR Parts For Sale
15-09-2015 03:38 PM
DixieTheKid
14-09-2015 09:04 PM
Tank Mike
14-09-2015 03:56 PM
grishenko45
09-09-2015 12:58 PM
