Cossie runs rough on start up when hot and cold
I have just put a new engine in my 4x4 but now its running it runs really rough on start-up. Sometimes struggles to fire when hot then once it does it sounds really choked up and revs to about 2000rpm then comes back down again . Its hunting a bit as well. Anyone got any ideas?
Originally Posted by Jasesapphy
Possible Coolent Temp Sender or possible plugs
Got spare temp sender if you need one
Right I have just been out in it again and have decided that its over fueling
the plugs are black but not wet and the oil is smelling of petrol When the old engine was in everything was fine with the new one this fult has developed. The only difference is this engine is 7.8-1 its really getting on my nerves now
Just been out looking at me car again and after a long time messing around i decided to change the injectors ,I had a set of standard 4x4 ones kicking around. Started her up and she runs really sweet !!!!!!!!!!!!!!!!!
It had dark greens in it seems to run alot better with the std injectors in but still rough on start up
well after much fiddling and taking voltage reading from the ECU, i have found that the CTS wires were fooked.
Cut the plug off, put a new one on and ...................
She's sweet
Cheers for your help guys
She's sweet
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
