Race bearings for Zetec Engines - where from?
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
What race bearings have people been using on their Zetec Turbos and where did they get them from?
Originally Posted by Stavros
Give RC Delvelopments a call, one of the lads there has a big spec Zetec turbo, he might know.
Hope this helps.
Stav
Hope this helps.
Stav
Did a little bit of research for you mate.
https://ssl.perfora.net/massivespeed...iew.shopscript
For starters, if i find anything else i'll post it here.
*** Sierra RS Custard ***
For anything upto what the standard crank can take (500bhp or so if rumours are true) I find it hard to beleive the standard bearings arent adequete
Thats NOT me giving an answer, i know little about the zetec really, its more of a question.
What bearing failures have you heard of?
The crank should have oil between it and the bearing anyway dont forget, the two should never actually touch in the first place.
Im not a fan of really hard bearings, as any tiny bit of swarf that gets into them ends up emebedded in the crank instead of the bearing potentially.
Nice soft bearing that can accept a little bit of shit, and a good supply of oil to keep it and the crank apart are the key to a good engine based on my limited experience of that subjet TBH.
Wear resistance is pretty irrelevant on a high power engine IMHO cause its never been a bearing wearing out that has required a stripdown ever on any high performance engine ive ever seen, they ALWAYS outlast the ringseal on a big power motor unless you have had an oil problem.
Chip-3Door true
i was just told they were heavy duty bearings when i was supplied with them after the machining work on the block, but after reading the website they didnt seem to be
DEYTUKURJERBS
As per chip- id be shocked to find bearings lasting less time than other parts IF the oil system was up to scratch.
And if tis not, fix that, not the bearings.
Originally Posted by sunny
500bhp, 186mph (178.8mph proven @ Brunters), various events and plenty of engine raping....std bearings were fine.
I hope that answers your question.![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
JoeyBoyden
04-01-2024 02:36 PM
track.focus'd
12-08-2015 05:53 PM
