discussion t3 v's t34 your thoughts advantages/disadvantages
Location: learnin to build a yb lump properly in dennis's garage
im running just 310 bhp with my rwd saph been offereda t34 for reasonable money, but i dont know any one with one or who has had experance with one,
what sort of gains will i see if any over a t3?
will it fit straight on in place of the t3?
i assume i will need to get my car re mapped am i correct?
what should i be paying for a 2nd hand unit?
i assume dark greens are suitable injectors?
can any one enlighten me especially if you have a t34 !!!!!!!!
Chasing Radders
I went from a T3 to my T34
The T3 was a fucking brilliant point and shoot car, as soon as you turned the corner the power was there
Then went to the T34 expecting a laggy car, mine has the .63 housing, BUT i was shocked, not as Resposive/punchy as the T3 but MUCH better when the boost comes on and holds the whole way
I am getting a touch more boost on the T34 soon so will be just as puchy i hope
IMHO Go for it mate
At the end of the day, if you dont like it, change back
You will need a re-map and the Greens will be fine
A good T34 2nd hand should be about £500
IMHO Go for it mate
well m8, ive just blown my turbo(t3) and i am going to get my car done with a t34, both set up at stu's ,same car , same engine etc so the only difference will be the turbo so i will be able to tell when i get it back, yes the chip needs to be a different set up to a t3 and as for injectors i think it doesnt have to be anything as standard escoz doesnt run greens , i think its just the fact that when people go for t34 its usually connected with wanting more power which goes hand in hand with bigger injectors etc, i'll know for sure shortly what the difference feels like so i'll let you know
impreza wrx sti version 8
but am i gonna see much more of a improvment performance wise? love the way it drives with t3 but think its at its limit! what about t38's? or is it all to do with the mapping? would like to to se 350-360 ish ideally but dont want the lag associated with a t4
Chasing Radders
Greys, T34 and Chip to suit
You will love it, BIG improvment. I LOVE driving it
JUST DO IT
Originally Posted by Dave Henshall
i had roughly the same spec as tiff
std c/r grp a head gasket
chip of stu
and the thing flew straight into a tyre wal...pmsl
but seriously, if setup right, it is VERY reliable conversion, i run 21psi held for 14k
chip of stu
i ran 15psi on my T3, and now run 20psi on a T34. Its a bit more laggier but feels so much better on boost.
Forget the T3, you're not getting the best out of your car with it. Get a T34 and get it mapped
ok gonna start saving me thinks, what sort of bhp/torque are you guys running?
PRIOR TO FITTING THE 5OO COOLER I WAS AT 310 BP 335LBFT
my stage one holding 15 psi was quite quck but did slow down when the speeds got up to about 135. new low comp re build with t34/0.55 holding 20 psi pulls like a train all the way past 155.
t34 well worth its money....got a really good deal from turbo technics on a stage 3 about half the price id seen elsewhere!
Grant, i am just moving from your kinda spec/power to t34/ greys/ 500 intercooler and will be running 28-29psi held My turbo was £500 and has recently been rebuilt then it was the purchase of greys, cooler, -34 actuator, then chip, then set up should alll be ready will a fw new bling and body mods by mid october
