Radiator options on s2 erst ???
Hi,
The car went to the garage today for a cylinder head leakage test as I thought the head gasket was on its way out ! It came back showing no signs of leakage which I was relieved about but they commented that the rad was leaking from both sides (which I knew anyway ).
now.........I go on holiday to kos on wednesday so I really need to let the garage know what I want done etc.. They said they can get rads for about £130 but I'm sure I have seen cheaper
Are standard rads copper, if not, is there any difference ?
whats the cheapest alloy rad available ?
anyone know any websites or company that sell rads for a good price ?
any help much appreciated
Duncan
Duncan
ideally I'd like an alloy rad but due to the holiday I dont think I can afford one
anyone know how much a new rad from ford is
would this be better than a copper one
cheers, Duncan
cheers, Duncan
i got my standard rs rad recored for 90 quid
anyone help with the other Q's
cheers, Duncan
problem with recored rads sometimes, where they use the origonal plastic
end tanks, they can become brittle, or have problems where the brass inserts
go in. if your end tanks are ok, then a recore should be fine, if not then its worth
getting a new one from your local Ford agent.
best of luck anyway
best of luck anyway
cheers, Duncan
cheers, Duncan
I have it hanging up in a frame in the living room
Check out the prices whilst you are abroad - you may get it cheaper
cheers, Duncan
Mc5506
05-10-2015 09:57 PM
