FAO SECS and other people too that might know!..LOL.
Old 13-09-2004, 12:09 PM
Ima-Racing500
Ima-Racing500's Avatar
Default FAO SECS and other people too that might know!..LOL.
If your about
I am using the 5 bar map sensor,do you have any idea on wiring?Iknow it plugs straight on the 2wd loom but do any wires need swapping?
Also the eec4 tps do i wire it as per 4x4 tps ie swap end wires round on 2wd loom?
Next question is.....the eec4 throttle body has a different connector to the 2wd/4x4 for the tps and the iscv,can i get those connectors????Anyone have them?Ford dont.
Thanks
Old 13-09-2004, 12:12 PM
zvhturbo
zvhturbo's Avatar
http://www.mmcompsys.com/sensors-pressure.asp
Click on APS Datasheet.
If that is any help
Matt.
Old 13-09-2004, 01:15 PM
Ima-Racing500
Cheers mate
BTTT
Old 13-09-2004, 02:35 PM
ECU Monitor Enthusiast
The 5 bars ground and 5 volts are swapped.
BOSCH 5 (FIVE) BAR
Pin 1 Signal output (same as 3 bar)
Pin 2 +5 volts supply
Pin 3 Ground
WEBER 3 (THREE) BAR AND 2.5 BAR AND 2.0 BAR
Pin 1 Signal output
Pin 2 Ground
Pin 3 +5 volts supply
Old 13-09-2004, 02:45 PM
Ima-Racing500
Oh..........the web site above says the 3 bar/2 bar is:-
A (1) +5 volts
B (2) Gnd
C (3) Sig Out
Old 13-09-2004, 02:47 PM
Ima-Racing500, wait a few minutes and I will post a diagram up here.....
Old 13-09-2004, 02:48 PM
Ima-Racing500
Cheers.........what about the TPS wiring????
Old 13-09-2004, 02:52 PM
Right,
The info I gave was from other sources but refers to the amp connector pin numbers.
(MAP SENSOR CONNECTOR)
Looking at 3 (THREE) BAR sensor with inlet hole facing you and connector at bottom......
From left to right
+5 VOLTS / GROUND / SIGNAL
The connector outline profile, has the single ridge pointing down....
If you wire the 5 bar up wrong you wont break it as I have done it !
Old 13-09-2004, 02:55 PM
Phil, You have the EEC4 type TPS, I dont have info to hand but generally,
Centre is the signal (to ECU pin 17)
The outer pins are either earth (11) or +ve (30) swap these two until you get it right.
Select 4x4 in the sensors setup on the S8.
Old 13-09-2004, 02:58 PM
foreigneRS
Testing the future
foreigneRS's Avatar
maybe you could also add this information to this topic?
https://passionford.com/forum/viewtopic.php?t=63256
Old 13-09-2004, 02:59 PM
Ima-Racing500
Cheers mate..aslong as no harm can be done i will experiment..LOL.
Old 13-09-2004, 03:00 PM
foreigneRS, Sorted just swap +5 and Ground for 5 bar Phil.
Old 13-09-2004, 03:04 PM
alex xr3 modded
alex xr3 modded's Avatar
fao secs steve long purchased a secs monitor off one of you r mate that didnt come with the leads for it how can i get this please as ive asked and asked
thanks mate got to sort this out for him and cand do anything without the wires bud???
Old 13-09-2004, 03:10 PM
If you purchased a monitor without a cable it was not from me or
not new.
Please send a mail to simon@s8ecu.co.uk with address details please.
NO ONE by the name of Alex (if that is your name) has asked me for a cable.
As for the name steve long dont know that one either.
Only one person AFAIK is waiting for a cable and that is MATT B.
Old 13-09-2004, 03:14 PM
alex xr3 modded
it was not a new one mate it was for my cousin butchrs500 on this board/ white rs500 with gold wheels now the wheels are black
Old 13-09-2004, 03:19 PM
alex xr3 modded, That name DOES ring a bell.
He did PM me a while back but I lost the PM when the board crashed a few months ago.
As I said, mail me an address and I will see what I can do.
Old 13-09-2004, 03:23 PM
Ima-Racing500
Well SECS has given good service so far
Keep it up
Old 13-09-2004, 03:25 PM
Ima-Racing500
I just hope he isnt another Rainbird and just trying to get into my y-fronts
Old 13-09-2004, 03:33 PM
alex xr3 modded
pm sent to you mate inc address to post as well thanks top class service thanks
Old 13-09-2004, 03:37 PM
Disabled Account
Disabled Account's Avatar
Phil,
Chosen/purchased your turbo yet?
MD240?
Old 13-09-2004, 03:46 PM
Ima-Racing500
Not yet.......putting engine in tommorrow and all that will be missing is turbo and intercooler.
Old 13-09-2004, 03:57 PM
Disabled Account
Shame you cant go out in Simon's car (because of the distance involved).....because I'm sure he would gladly take you for a spin
Anyway, his Es Cos is a very good advert for the MD240.....absolutely amazing spool up from quite low revs......Iv'e driven it a few times now and it sooo impressive,,,,,,,and he's not using huge boost either
Makes a T4 feel like a truck turbo..........lol
Old 13-09-2004, 04:02 PM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
A T4 IS a truck turbo
Old 13-09-2004, 04:08 PM
Disabled Account
Stu, I know, I know............
And Simon takes every oppertunity to remind of the fact
Old 13-09-2004, 04:23 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
I like MY truck turbo - 15psi by 3150 and 33-34psi by 3500 .
Old 13-09-2004, 04:53 PM
Shows how bad my setup is im on a t34 and i get 5psi by 3000 revs lol its bad i know
Old 13-09-2004, 04:57 PM
Rs Gus
impreza wrx sti version 8
Rs Gus's Avatar
i get 35psi@3500rpm
Old 13-09-2004, 04:58 PM
Dave Henshall
Dave Henshall's Avatar
could be a duff wastegate there mate..?
Old 13-09-2004, 05:09 PM
Na i have replaced the actuator with a -34 or do u mean the actual wastegate in the turbo??
Old 13-09-2004, 05:22 PM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Phil, When are you gonna have your car running so you can tell us what SECS's ecu is like.
Old 14-09-2004, 07:34 AM
Dave Henshall
possibly, or blowing exhaust manifold gaskets - both cosies ive ad have been blowing. abour 20 quid for a set of 4 from ford.
Old 14-09-2004, 08:09 AM
Mike Rainbird
Caraholic
Gus,
Yours isn't a T4 . Pretty pleased that my T4 spools up as quick as a T3/4 though - goes to show that the design remit was achieved .
mk3ste
17-10-2021 10:09 AM
Rsmat
89
12-10-2015 07:50 AM
Adam-M
Was It You?
01-10-2015 07:55 PM
A.t.p
29-09-2015 05:04 PM
rsguy
44
29-09-2015 03:29 PM
Quick Reply: FAO SECS and other people too that might know!..LOL.
