AP Disk help
Old Mar 11, 2007 | 08:55 PM
  #41
http://cgi.ebay.co.uk/DUCATI-748r-SE...QQcmdZViewItem
http://cgi.ebay.co.uk/Ducati-Brembo-...QQcmdZViewItem
..better?
  #42
GARETH T's Avatar
GARETH T
Originally Posted by NUTS RuS
RWD_cossie_wil
You need a diferent shaped hole in the disc
Gareth will tell you its technical name but we call it "oval"
i rather the term slotted or elongated
Old Mar 11, 2007 | 08:56 PM
  #43
RWD_cossie_wil's Avatar
RWD_cossie_wil
whys that then NUts? to allow un and down play as well as axial?
Old Mar 11, 2007 | 09:02 PM
  #44
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Originally Posted by Bosch-Man
http://cgi.ebay.co.uk/DUCATI-748r-SEMI-FLOATING-DISCS_W0QQitemZ290090007169QQihZ019QQcategoryZ1044 8QQrdZ1QQcmdZViewItem
..better?
If that reply was aimed at me then I'm less than impressed! Don't quote eBay ads... Let's have it in your own words... I have given my account of why the AP disc imho IS fully floating (again I will mention radial + axial) now let’s have yours...... waiting!
Old Mar 11, 2007 | 09:04 PM
  #45
Martin-Hadland
your disc probably wont have the enough metal in the area's needing machining to make them floating..
Old Mar 11, 2007 | 09:10 PM
  #46
NUTS RuS's Avatar
NUTS RuS
and if they are under 350mm its not necessary
Old Mar 11, 2007 | 09:19 PM
  #47
Tony Ryan's Avatar
Tony Ryan
RWD_cossie_wil
Or a slot in the Bell like the Alcon method , insted of the bobbin slotting into the disc it bolts flush to the face and the bell moves .
The term fully floating is normally used to describe the twin bearing type of live axle , salisbury , english etc.. Its just been bastardised by the people that think "fully " means their floating discs are better than others and worth more .
Old Mar 11, 2007 | 10:56 PM
  #48
...martin i have had a 916bp with semis...they are not riveted and the disc hardly moves....my sp the discs moves alot...hence fully floating
..i think tony has cleared it up.
HTH
Old Mar 12, 2007 | 07:59 AM
  #49
Martin-Hadland
HTH
I don't think Tony has cleared it up at all! He merely mentioned that some manufacturers use different methods of creating float.
You have still not explained the differences between the disc mountings on your bike other than one has more play than the other Perhaps one is worn more than the other....
Anyway it's a bttt for the folks who havn't seen what a plonker you are making of yourself over this
Old Mar 12, 2007 | 09:37 AM
  #50
Franco's Avatar
Franco
Originally Posted by Franco
Anybody got a front & rear picture of a 355 floating disk fitted to the bell (with bolts & bobbins assembled).
Not 355 but here is a fitting guide for floaters
Lay disc face up
Install the float bushes (or bobbins as you call em )
Turn over and fit the screws (and if supplied domed washers - dome up)
Add loctite now (not prior to screwing in)
Torque to 11 - 14Nm
HTH
Nice photo's but no help whatsoever to Mr Franco as the pics show the Brembo system!
Oh this is so yesterday, Martin i wouldnt waste your time!
Cheers for that Nuts!
https://passionford.com/forum/viewto...277&highlight=
Old Mar 12, 2007 | 11:19 AM
  #51
Martin if you havent worked out what it all means then i feel a little embarrassed to have to tell you...semi floating dont move as much as fully floating note how the fully has more bobbins or whatever you what to call em,allowing more movement?....your AP's may do the same kinda movement radial and axial but are not classed as fully floating touch a fully floater and you will see what i mean...lets just stick to AP's are floating to end it not semi not fully just floating.
...gotta go look for a fresh fish now
yatta
May 21, 2016 10:31 PM
Sp3no
Sep 27, 2015 07:23 PM
SteveT
Computers, Consoles and I.T.
Jul 3, 2004 05:51 PM
