help engine builders
Old Sep 11, 2004 | 10:41 PM
xr4x4rs's Avatar
xr4x4rs
Default help engine builders
ive almost got my bits for my cosy engine the spec is as follows
fully lightened and balanced bottom end
cosworth forged grp a pistons +25 7.2:1 cr
polished and ported head
bd14 inlet and exhaust
verniers
t35 stage 2 hybrid .63ex
mongoose exhaust system
2wd drive manifold
external wastegate
grey injectors
500 intercooler
spec-r grp a twin pot breather system
turbo pre rad
all arp bolts bottom end and flywheel
the problem is because im reshelling the car its going into a k reg xr4x4
how do i sort the cat and emissions out for the mot as the engine came out of a j plate car which didnt have a cat
also what sort of power would i be expecting from this engine
once the car is ran in its going to ma developments for a map and setup maybe a closed loop lambda control aswell as these are the boys ive heard of a lot of people espicailly my mate who just had his turbo dun there
any help much appriciated thanx
Old Sep 12, 2004 | 06:32 AM
pugo's Avatar
pugo
depending on the build and map somewhere between 350-400!!!!
pugo
Old Sep 12, 2004 | 08:16 AM
swerv's Avatar
swerv
yeh no less then 400hp as long as the heads been done right, so the car is a 93'k then , i dont see a problem with emmissions if you are getting it mapped
Old Sep 12, 2004 | 08:25 AM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
my k reg 4x4 very nearly passed a cat test without the cat but ny testers a bit freindly to me
Old Sep 12, 2004 | 08:32 AM
Stu @ M Developments's Avatar
PassionFords Creator
If your taking her to Mark at M.A.D for Closed loop fuelling (Presumeably on Autronic management?) then he will be able to do everything you need for the MOT so stop worrying.
technically you need a catalyst fitting (Std 92> Exhaust) but this really neds to come back of to have any reliable power unles you go for teh new generation of performance catalysts and of course you will be having a lambda sensor installed in the downpipe to feed the ecu with closed loop info on fuel mixture.
Hope this helps.
Old Sep 12, 2004 | 08:56 AM
Disabled Account's Avatar
Disabled Account
Default Re: help engine builders
verniers
2wd drive manifold
external wastegate
grey injectors
500 intercooler
turbo pre rad
Very nice spec - but with that comp ratio (7.2:1) I would seriousely consider a change of turbo to a T4. The T34 will give you 400-412 BHP absolute MAX (@ 26-28 LBS/PSI)...and it will be working VERY hard to achieve that figure......If you fit a T4 turbo (or a GT Series equivelent) you can then take full advantage of that nice low comp ratio by runuing higher boost safely (32-34 LBS/PSI) and get an "easy" 460 BHP......and to a T4 that 460 BHP will be a "walk in the park"....i.e. fairly unstressed
ALSO - If you ditch the greys and fit 750 - 1000cc MSD intectors you will get nearer to 520-540 BHP with good torque - no problem AND if mapped correctely with closed loop lambda very good emissions/idle behavior.
Ask Mark Shead (NA Developments) for confirmation
Old Sep 12, 2004 | 04:30 PM
martrs's Avatar
martrs
Rich you no what i thinck m8
Old Sep 12, 2004 | 04:36 PM
Disabled Account
martrs,
What are you thinking?
Tell, tell please
Old Sep 12, 2004 | 04:48 PM
martrs's Avatar
martrs
Just a joke m8 trying to get him to buy my car
Old Sep 12, 2004 | 04:50 PM
xr4x4rs's Avatar
xr4x4rs
wud love to but it mate u know i wud but all my funds are on the cosy at the mo as u already know unless u wana do it on the tick lol
Old Sep 12, 2004 | 04:52 PM
Ima-Racing500's Avatar
Ima-Racing500
Put a std exhaust cam in though!!!
Old Sep 12, 2004 | 04:54 PM
xr4x4rs's Avatar
xr4x4rs
as for the t34 thats only going to be on the car while i run the engine then it will be a gt35 turbo
but before this im running the engine in on standard transmission so need to get 3300 grand together for a big tooth kit or else if i have it mapped and setup the gearbox will be like cadburys choclate on a hot summers day
as i used to go through a gearbox al,mmost every month because the place i used to use there gearbox specialist carnt builkd them wont mention any names of that company hey martrs
Old Sep 12, 2004 | 04:58 PM
Disabled Account
xr4x4rs, GT35 A proper turbo then
Old Sep 12, 2004 | 05:01 PM
markk's Avatar
markk
xr4x4rs,
this is not a problem if the mot station knows the rules !! if you can prove the year of the engine then it wil be tested as per engine manufacturing limits !!
xr4x4rs,
if your on about closed loop emission control on the std ecu for your J plated car then it needs to got 'MSD' motorsport developments for the closed loop control to be mapped in , that way your emmisions will be more than acceptible for your car anyway !!!
Old Sep 12, 2004 | 05:50 PM
xr4x4rs's Avatar
xr4x4rs
thats the company im running level 8 on the cos with pectel board for the greys so could really do with the closed loop lamda on it but have to get the car mot and taxed first before i can either start running it in
also what sort of exrernal wastegate wud be wise to run
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
