Cossie , fuel filter question???? help
About to fit my 044 pump on my 3dr cosworth guys BUT on getting under the car to do so , noticed my fuel fulter is a cheapo little fuel filter , the clear ones you would get in a nova or something
Can i change back easily to the proper one >? though it should be the "can" type and not with jubilee clips at each end ? any help appreciated , on why i would have this , surely its not normal ????
1 Post
uses banjos, buy a filter from ford, go to pirtecks or hypehose they do adapters that will fit, couple jubliee clips and some fuel injection pipe, job jobbed
At a bit of a crossroads euan have these light blues here , but cars running at moment with the greens , going to get this pump in and get her to ava to set up , but think its a waste if im putting these blues in it but need a chip etc , would ava hook me up with what i need for the blues ?? want it better and rolling roaded for crail , but maybe doing the blues is goiung to set me back time and effort and money for the sake of a month or so , hope this makes sense
what turbo do you have Rab?
Do you want to really push the engine to the point where you will max the greens? (300 ish ATW)
AVA can sort you out with what ever you need Rab
The hing is got these blues for a bargain so kind of want to use them and heard there slightly better all round , anyway 300atw max for me , anything over 270ish i`d be chuffed with , probably , again im running 13psi just now and dont ever nail it , and need to get this thing squating !
dont bother with the blues at the moment then Rab as 280 is no probs for the greens.
Just get to rollers and get it set up the blues just complicate things and they arent really needed at this spec level.
25 psi will feel ALOT quicker than 13
Stu this is true ,iL get a picture , was pretty shocked when i seen it as well , dont know the science behind it all but knew it was`nt what i was suppose to be seeing
Why would someone do this ???
kosienutter
31
22-08-2015 09:55 AM
ekjim
17-08-2015 08:57 PM
CabrioTurbo
01-08-2015 11:04 AM
