Help!! Cossie fuel cap is stuck on
As above on my Sapphire, I went to fuel it up and cant get the cap off. Tried WD40 and jiggling it about but will it hell move.
Anyone had this problem or got any suggestions as Im seriously low on fuel and I dont dare use the car now.
Cheers.
Cheers.
WD-40 isn't the best thing to use on locks. A graphite based 'dry' lubricant is recommended for locks, although adding it now may not be the best idea.
When you eventually get it off, do what I did.
I bought a complete lock replacement kit from ford for not that much (less than £50) which provided me with a complete set - Ignition, two doors, fuel cap and boot.
I did mine, and it was like a new car! I was having similar issues with my cap as well
I konw this wont help you get the thing off, but when you do, it will help you solve it in the long term
JJ
JJ
Originally Posted by avid-fan
is it a locked metal one or plastic version
The key doesnt want to turn any more than maybe 10mm and then thats it. Its pissing me off now cos I need to use the car as my ZX runaround has blew its radiator.
Its off with a little persuasion. Had a right fart on but it works again (With any Ford key now though)
Ill buy a new lock set cos the ignition barrel is worn too and can be a righ sod!
Matt Baxter
16-09-2015 08:30 PM
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
