Dump valve on a supercharger - can it be done?
Coldo loves seamen
Easy enough question, one ive wondered for ages, ive got a mini cooper s, can you put a dump valve on them? Ive heard both stories, that you can and you cant so was wondering if anyone actually knew the truth? Just wondered cos i saw this Clio V6 supercharged and it dumps!!
http://www.youtube.com/watch?v=zZvcQ27aWmw
Yes you can. Exactly the same method as per turbo car.
Trouble is, super chargers boost levels rarely rise above 1 bar of boost
so generally a dump valve isnt needed as also, the charger is engine
driven so is less likely to slow down with reverse air flow.
Pointless IMO unless really wild set up - Unless you just want the sound
DEYTUKURJERBS
Originally Posted by SECS
Trouble is, super chargers boost levels rarely rise above 1 bar of boost.
Ive seen CooperS's on stock chargers running 24psi, never mind other stuff.
Charger will never slow down due to reverse airflow unless the belt slips/snaps unless we talking about homo centrefugual chargers, and the CooperS has a "real" one.
Infact there will be no reverse airflow, on a proper charger as they sealed units, positive displacment devices, when the throttle shuts (if the throttle is AFTER the charger, i think it is on a Mini), unless there a bypass or vent that opens every time the throttle shuts there will be a massive boost spike before the turbo, not any reverse flow.
Minis have bypasses as standard, IIRC its a small throttle type flap opened by a wastegate actuator looking thing.
Dumpvalves are homo, if you want good noise, just fit an induction kit and a smaller supercharger pulley to speed up the charger rpm so you get a much louder whine
Coldo loves seamen
Monte 087
I used to have a golf G60 and on the bottom of the throttle body was another butterfly when the throttle was fully shut it was open and this just redirected the air back into the charger so it basically just recirculated the air untill you opened the throttle again, alot of ppl with them used to blank the side of the charger off with the boost return pipe on or fit twin inlet kits to them so the charger was sucking from both sides and just let the throttle body vent to atmosphere thus making it in effect dump off was supposed to cool inlet temps down aswell never bothered doing it with mine.
My 1960's Shorrock has a 'Pop Off Valve' to release pressure not when you change gear like a Chump Valve but to release pressure if the level of boost gets too high, for whatever reason, be it the engine over revving etc
Isn't a supercharger constantly boosting? I remember the G60 had a valve that was open most of the time which gave it that hissing sound character.
Do we put the dump valve on the pipe after the internal valve?
Coldo loves seamen
Just put my induction kit on monday there - HOLY SHIT. The noise is incredible!! Sounds like a bloody x-wing from star wars! Only problem is, cant keep my right foot off the pedal cos i love the noise
DEYTUKURJERBS
Minis have PROPER Eaton superchargers, so whines like fuck.
Smaller pulley for more boost and the noise goes all WW2 fighter spec
DEYTUKURJERBS
I dont know, or really give much of a fuck, but proper chargers do it, gay centrifugal ones dont really, so its something proper ones do that belt driven turbo compressors dont.
Happens more the more load you put em under too, so more charger rpm or if you shut the throttle on one without a bypass.
So its summat to do with that, what exactly, i dunno.
is awesome
Originally Posted by Porkie
Originally Posted by Hooligan
I love the really loud supercharger whine
DEYTUKURJERBS
Originally Posted by AlexF
What drives BOTH screws?
What also makes a similar noise on rally cars (or minis )
Alex
Alex
That dont make total sense to me as a lot of the noise is muffled by airboxes etc and gets tons louder with an induction kit etc.
Also centrifugal ones run straight cut cogs too but dont whine anywhere near as much, if at all, sound more like turbos.
So maybe thats some of the noise, but that dont make sense for some of it!
Its probably a bit of both!
moving air is fucking noisy no matter how you do it!
Its DEFINATLY a cool noise
in fact I'm going to go make mine make it as often as possiblr for the next 40 mins
Alex
Alex
charger, cooper, doesnt, dump, install, mini, open, run, super, superchagers, supercharged, supercharger, superchargers, surpercharger, valve, valves
