TPS question
Old Feb 21, 2007 | 08:16 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Default TPS question
Now i was led to believe that 2wd tps were red and 4x4 were black and were listed as pf01 for 2wd and pf09 for 4x4, now i needed a 4x4 as my magenta saph is running L8 and had been run with a 4x4 tps with the two outer wires swaped, so i got a black tps sent down from Paul at NYRS and find it has pf01 stamped on it, i also have searched ebay to find a red one advertised as a pf09, wtf is going on, by the way this is in no way a dig at Paul as he genuinely thought the same as me and that they were colour identifyable.
Sorry to ramble on a bit
Steve.
Old Feb 21, 2007 | 08:21 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Hi Steve,
I run with a L8 and my pf09 is grey.
How is it running ?
Steve.
Old Feb 21, 2007 | 08:22 PM
Stu @ M Developments's Avatar
PassionFords Creator
Red was fitted at the factory. Both PF01 and 9 were red back then.
ALL weber Aftermarket are black.
Examples:
http://stores.ebay.co.uk/Motorsport-...QQftidZ2QQtZkm
Old Feb 21, 2007 | 08:25 PM
nellyscossy's Avatar
nellyscossy
i was led to believe that red is 2wd and black 4wd didnt think number matters......
anyhow my car is running 4x4 management with a 2wd engine and the tickover is too high (unless i unplug the iscv)i was told that i need a 4x4 tps to cure this......
p.s. sorry to hijack your post!!!!!
Old Feb 21, 2007 | 08:28 PM
Moonstone Steve.
Mine is the same m8 a 4x4 tps will cure it.
Steve.
Old Feb 21, 2007 | 08:29 PM
Anyone running a L8 and NOT changing teh TPS and the wiring is asking for trouble. The system will NEVER run properly with the wrong TPS.
Old Feb 21, 2007 | 08:31 PM
Moonstone Steve.
Examples:
Thanks Stu, so going by colour alone isnt the only way of id.
Steve.
Old Feb 21, 2007 | 08:32 PM
nellyscossy
in that case i need a 4x4tps!!!
Moonstone Steve.
Originally Posted by cossie4i
Hi Steve,
How is it running ?
Steve.
Hi Steve, running low revs on cold tickover and high on warm.
Steve.
Old Feb 21, 2007 | 08:40 PM
Moonstone Steve.
so when fitting is there as setup procedure i need to follow.
Steve.
Old Feb 21, 2007 | 09:55 PM
JjCoDeX75's Avatar
JjCoDeX75
You need to make sure that you follow the correct procedure for setup, else you will have all sorts of probs with your ICV
The base voltage needs to be less than 0.6 volts when at idle. MEasure with a voltmeter at the ecu plug end. I believe it is pins 30 an 17 to measure across, but dont quote me.
I have a sheet that tells you the Ford how to guide. PM me your email address and I will forward the manual to you
JJ
Old Feb 21, 2007 | 09:56 PM
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
Steve.
yes,make sure its not reading negative degree's,i had a right nitemare with this problem,
tps are exactly as stu says,ive a pf09 here if you get stuck.
Old Feb 21, 2007 | 10:03 PM
Moonstone Steve.
JJ
JJ you av pm m8.
Old Feb 21, 2007 | 10:04 PM
Moonstone Steve.
Steve.
tps are exactly as Stu says,ive a pf09 here if you get stuck.
Thanks for the gesture m8 , Paul is going to get me one out in the post tomorrow.
Steve.
Old Feb 21, 2007 | 10:10 PM
Mr RS500's Avatar
Mr RS500
Sorry about that steve
As they say , you learn summat every day
Will post another asap
Old Feb 22, 2007 | 07:25 AM
Moonstone Steve.
Originally Posted by NORTH YORKS RS SPARES
Sorry about that Steve
Thanks m8, it caught us both out that one.
Steve.
Old Feb 22, 2007 | 08:45 AM
Steve...to set the TPS up is just put it on turn it and let it spring into its position and then tighten screws..thats how i always done it!!!
Old Feb 22, 2007 | 11:26 AM
JjCoDeX75's Avatar
JjCoDeX75
This is the way that the technical tuning manual tell you to do it, though in my experience, this doesnt always give you the correct result.
Best is to set up with a multimeter if possible, else the above is second best.
Moonstone Steve - Dont have a PM yet matey - need your email address!
JJ
Old Feb 22, 2007 | 11:51 AM
Moonstone Steve.
JJ you av pm m8
Steve
Old Feb 22, 2007 | 12:05 PM
JJ he has a SECS moniter...providing that says 100% at full throttle..its fine
Old Feb 22, 2007 | 12:20 PM
far from fine pal.
Idle is more critical than WOT when adjusting.
Old Feb 22, 2007 | 12:26 PM
....never had an issue yet
Old Feb 22, 2007 | 04:19 PM
JjCoDeX75's Avatar
JjCoDeX75
Aha! If he has a SECS ECU then this should help, but when my TPS was set incorrectly, the ICV didnt operate, and the idle was up at crazy rpm. Even so, the tps delivered 100% at the top (but was too high at the bottom)
JJ
Old Feb 22, 2007 | 06:27 PM
Moonstone Steve.
JJ.......Thanks for the tech sheet will browse through when i get time
Steve.
Old Feb 22, 2007 | 07:23 PM
Mr RS500's Avatar
Mr RS500
Steve
New CORRECT item is on its way
Old Feb 22, 2007 | 11:34 PM
JjCoDeX75's Avatar
JjCoDeX75
Steve.
NP Any queries, give me a PM
JJ
Old Mar 10, 2007 | 04:45 PM
nellyscossy
just put a tp09 on my motor...hey presto..instant tickover
Old Mar 11, 2007 | 01:37 AM
Micky The Finn
Former Sponsor
whats one of them then?anything like a pf09?
Old Mar 11, 2007 | 10:09 AM
nellyscossy
theres me getting my bloody letters mixed up ........i meant to say ive just fitted a PF09.........
Old Mar 11, 2007 | 11:54 AM
Billabong's Avatar
Billabong
Steve.
Colour is the last way to identify a part - always go by the part number.
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
