FAO anyone that knows the cossie water system well UPDATE
Old 06-02-2007, 03:52 PM
Roosie
500bhp Cosworth in making
Roosie's Avatar
Default FAO anyone that knows the cossie water system well UPDATE
my other post explain a prob i have.
i have no water going to my matrix bit it does flow pk as i put a hose in 1 end and it come out fine.
i took the metal pipe that goes accross the turbo manifold to matrix off and started car and its not flowing water at all. neither is water going from head to oil cooler pipe,
can someone tell or show me the way the water system flows ie were does it go from the header tank ect as im confused why water aint flowing to my matrix. ive took the thermostat out aswell to make it flow straight away but no avail
Old 06-02-2007, 03:58 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Sounds like you have a water pump problem......................
Old 06-02-2007, 04:02 PM
Roosie
Roosie's Avatar
well i would have thought with even with a lazy fuel pump it would flow a little but not at all?????
its been like it since i had it engine still stays cold ect just no heat seems like a water block
Old 06-02-2007, 04:51 PM
CosKev3
CosKev3's Avatar
LOL
The impellor blades on WATER pump could have come off theshaft that belt drives on pump,not seen it on a cosworth before but have seen it on other cars
Old 06-02-2007, 04:56 PM
Neil S
Neil S's Avatar
I'd say it was your water pump, or an almightly airlock somewhere. What happens when you open the bleed screw with the engine running?
There should ALWAYS be flow through the engine and heater matrix, regardless of what your thermostat is doing
Neil.
Old 06-02-2007, 04:58 PM
Roosie
Roosie's Avatar
i took air screw out of housing and the water comes out little bit but constantly if u take the cap of the header tank its shoots out constantly!
Old 06-02-2007, 05:00 PM
Roosie
Roosie's Avatar
i think there is a little water going through the matrix but not a lot.
Roosie
Roosie's Avatar
does anyone know which one is water feed to the matrix top or bottom
Old 06-02-2007, 05:03 PM
Roosie
Roosie's Avatar
Neil.
surely that will mean the engine will run hot as it dont and its been like this since ive had it and its done 300miles ?
Old 06-02-2007, 05:37 PM
Roosie
Roosie's Avatar
so does no one know what way the engine coolent system runs?
Old 06-02-2007, 06:07 PM
Csm
Csm's Avatar
coolant runs in via the top hose
Old 06-02-2007, 06:22 PM
Roosie
Roosie's Avatar
brillaint so the coolent runs through the metal pipe on near manfold from the front and goes towards back of engine into matrix.
my thermostat is not in so why fa fook is there no water going up there?
there is water to the thermostat housing then it goes to the matrix unless that little 90 degree bend between the thermostat and the metal pipe is blocked!
Old 06-02-2007, 06:34 PM
Graceland
Team HOTHOT!
Graceland's Avatar
As previously said, your water pump is bolloxed
Old 06-02-2007, 06:38 PM
Roosie
Roosie's Avatar
any way of confirming this without taking it off.
and is it a big job
Old 07-02-2007, 09:23 AM
Roosie
Roosie's Avatar
took water pump off!
all ok
blades are still there spins ok no leaks (even tho th epipe split that goes to water pump to thermostat housing when i took it off.
oh well thats one thing off the list that it could be
Old 07-02-2007, 09:29 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Check the foot-wells (normally passenger side) for any signs of water. It could be that the matrix is pissing this out into the footwell, but you should be able to smell the coolant inside the car and see the level changing.
Old 07-02-2007, 09:47 AM
Roosie
Roosie's Avatar
nah mate matrix is fine no leaks at all.
goto get a new thermostat hosuing as mine is starting to corrode
anyone know if there expensive
Old 07-02-2007, 09:54 AM
Tony Ryan
Tony Ryan's Avatar
Does the engine run hot at all ? You say in one of your posts that if you remove the Header tank cap it gushes out , this is normally what happens when you have a head gasket failure but im wondering if you have a really badly blocked rad , they get furred up with crap both sides at the bottom blocking half of the rad off , this would make it run hot but i dont see whay it would stop water getting to the heater ?
Old 07-02-2007, 10:25 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
funny you say that mike
just as i pulled into the park earlier to park up the drifter for the day, the windows instantly steamed up and i couldnt see fook all, then smelt summut, looked down and sure enough, the pass foot well was filling up with water
arsecheeks
Old 07-02-2007, 10:37 AM
Roosie
Roosie's Avatar
ok well its on hold for today i think as i need a new thermostat housing as mine has started to corrode also i need a pipe that goes from housing to water pump as i split mine when taking it off!
Old 07-02-2007, 10:55 AM
Roosie
Roosie's Avatar
ok just done compression check
1= 120
2= 117
3= 119
4= 120
Old 07-02-2007, 11:08 AM
ballin
ballin's Avatar
drain the system, shove a hosepipe on each hose or where you think the block is and hammer it.
if water comes through everywhere easily AND back out the other side of where it should be coming then no blocks, thats where i would start
Old 07-02-2007, 11:17 AM
gingeRS
gingeRS's Avatar
do this
if you can put water up through the bottom hose away from rad, through rad, and also through head and heater matrix, at least that way you can confirm there is no blockages.
and go from there.
Old 07-02-2007, 11:28 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
thats why i asked what colour the water in the header was lol
clean or dirty lol??
Old 08-02-2007, 12:04 PM
Roosie
Roosie's Avatar
right started my car up again today after putting a new thermostat and checked the water pump all ok.
must be matrix!
someone said on here water enters via the top hose into matrix!
well why when i take the bottom hose off and start the car the water comes out from the hose and not from the matrix, beacause if it was entering the matrix throught top then goes through the matrix and out the bottom, mine must be the oposite on this case
can someone confirm or dissagree that the water should enter through top hose or exit?
Old 08-02-2007, 04:54 PM
Neil S
Neil S's Avatar
The question is meaningless - what happens if someone has swapped the hoses on the matrix?
Ask whether the flow is from the Thermostat housing to the Modine or the other way round
Neil.
PS I'm not being funny - I don't know which way it goes, and would like to know
Old 08-02-2007, 05:26 PM
markk
markk's Avatar
i have changed countless heater matrix in sierras over the years, if the car keeps its temp ok when running and on boost, just no heat its the matrix, very few pumps fail on cossies, as tony says above check the rad when warm (runningtemp) feel the rad all over if its hot all over its gen ok
Shaunc
Escort Range
22-09-2015 06:38 PM
Bransby
21-09-2015 05:29 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
ST-170
04-09-2015 11:02 AM
Quick Reply: FAO anyone that knows the cossie water system well UPDATE
