What voltage do you have on idle in your secs monitor ?
I have to say, I remade the ends that connect to the positive terminal (all the little ones that bolt onto the whatsit) and gained an entire volt!!!!
JJ
JJ
Originally Posted by KSA-Cossie
Just the little wires m8 ?
JJ
358bhp
1 Post
snap! - 13.7 here to after the first rev.... before that it starts and shows 10volts. one (and only one) rev to 3k and it jumps up to a rock steady 13.7...
is that bad about the rev to kick start it? alternator on the way out maybe?
JJ
Originally Posted by SECS
The alternator needs an RPM above normal idle for a fraction of a second
BEFORE it starts to charge. This is normal
JJ
JjCoDeX75,
depends how slowly you rev it up
A blip at 3000 rpm will do the same job as a long blip at 1800 rpm.
But yes if it needs 3000rpm then its on the way to heaven...
My boat was shite - it would have to be reved all the way up under load to 'encourage' the Alternator to charge, then it would usually shed a belt! Class! You have to love that sea water!
JJ
I hope by the term boat you dont mean your saff
My boat......
JJ
Nice
Just needs some bonnet vents
JJ
TPM961
15-01-2018 10:50 AM
