Couple of Esc Cossie Sensor questions
Monte Geek
What thread is the water temp sensor? Does the ECU use it at all? or does it only show how warm the water is in the binical dash?
Oil switch, simular questions, thread, Does the ECU use it? or does it only show the oil pressure in the banana pod binical? does the same switch also do the low oil lamp in the dash binical?
1st to 200 without NOS
Re: Couple of Esc Cossie Sensor questions
Originally Posted by Paul Ripley
What thread is the water temp sensor? Does the ECU use it at all? Cheers
edited to say gays reply faster!
Caraholic
OMFG Mike where are all these Stack sensors going to go (real tears)
Thanks for the pm Martin will get back to you early next week
if you use a aeromotive fuel reg you can use the hole in the front for a sender, the water sender in head is 1/8 NPT, IRC so is the spare port on the oil pressure sender...???
Monte Geek
Not had the most suscessful day with the stack sensors
The new water temp sensor wouldn't fit in the old sensors position as it much wider so I'm going to have to get one of these once i work out the right hose to cut and get the id
I need a Oil pressure sensor and a Oil temp sensor so was going to use one of these:-
However made a bracket for the Speed sensor today that worked out better then i thought
As for the fuel pressure I was thinking of getting Harvey to silver solder the boss onto the standard rail
Monte Geek
So for the speedo I need to measure my tyre with a tailors tape and enter that in to the stack along with the number of pulses (being 12 bolts..) and thats it?
Good idea on the thermostat housing
I put mine into the thermostat housing .
Mike,
That will ONLY show the temperature of the water going to the rad
when the thermostat is open.
Dont forget, the thermostat doesnt stay open all the time.
Also, if the thermostat fails shut, you wont know about it till the head
gasket fails.
Monte Geek
How about the oil cooler water hose that comes from the ECU's water temp sensor housing if you can get an adapter small enough?
Dave which bit do you mean?
Paul,
I suppose any hose that has water coming OUT of the head as near as possible
such as the pipe going to the oil cooler or the turbo cooling
could be used.
One back for Mike R I guess...
could be used.
Caraholic
Simon,
I monitor it from EVERY position, as I have Pectel monitor for head, Stack for incoming water and Defi for out-going water.
I can then see how efficent my cooling system is or when it is struggling.
Paul,
As you have the Pectel monitor, you can put it where you like - I forgot to mention that where I have put my Stack sensor will give a low reading as that is after the radiator. For a temp as close to the Pectel as possible, it needs to go where you can see the Defi one is .
As you have the Pectel, you can chose where-ever you want to measure the temp from .
The STACK fluid sensors are 1/8 NPT.
Paul,
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
