Getting SECS Friday
Old Sep 7, 2004 | 04:13 PM
Ima-Racing500's Avatar
Ima-Racing500
Default Getting SECS Friday
Yep Simon told me on the phone i'd get it FRIDAY.
This is crucial to my specification as it will enable 8 injectors instead of going for the 4 big un route on L8.
I am confident he will deliver....do you think he will?
Old Sep 7, 2004 | 04:20 PM
Stu @ M Developments's Avatar
PassionFords Creator
I also have an item coming Friday Phil
*Awaiting droll comments about Stu and Phil both having SECS on Friday*
Old Sep 7, 2004 | 04:24 PM
R4N SS's Avatar
R4N SS
Phil - i thought u were gonna keep the saff std?
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
SECS is the only sex the two of you could get .
Old Sep 7, 2004 | 04:28 PM
JAP CRAP's Avatar
JAP CRAP
Stu.
wouldnt be the first time though hey
Old Sep 7, 2004 | 04:31 PM
Disabled Account's Avatar
Disabled Account
Default Re: Getting SECS Friday
Phil 8 injectors?
Why you no listen - are you mad?
Explain pleeeease why you must have 8 injectors (WRC style I take it?)
Old Sep 7, 2004 | 04:34 PM
Ima-Racing500
Doug...i have NEVER had a problem with 8...so why change?Plus it looks cool
You were UNLUCKY...and only had a problem due to incompetence it would seem!
Old Sep 7, 2004 | 04:42 PM
Disabled Account
But Phil where are you gonna take your car so that peeps will look at your 8 injectors and say "Hmmm 8 injectors - thats cool" ?........Iv'e not had ANYBODY say that to me yet......And I get around a bit lol
Old Sep 7, 2004 | 04:50 PM
Ima-Racing500
Your using the 500 plenum though....the WRC one hits you as soon as you lift the bonnet....anyway i never hit boost so they may aswell be disconnected!
Old Sep 7, 2004 | 04:53 PM
Billabong's Avatar
Billabong
Fair point, but why not take advantage of the S8's extra features etc? And, I think the "...is 4 inj's safer than 8 inj's?" has been done to death on here before now (from a potential mechanical failure point of view).
Old Sep 7, 2004 | 05:10 PM
Mike Rainbird
Caraholic
Doug,
You're thinking like a plonka .
KEEP your RS500 plenum, put four yellows in the usual place and four 1000cc ones in the back of the plenum. In normal running it has the fuel economy of a standard car, then at the point the yellows run out of injector time, phase in the 1000cc ones until you are only running these for hard use. You then have the four injector reliability (apart from the phase over point, but you would soon notice if an injector had failed as at full boost it would only run on three and at low speed it would only run on three. The SECS can run different types of injector AND the phase in can be done at any point and any split .
Old Sep 7, 2004 | 05:21 PM
Ima-Racing500
So i could do that then......
Mark Shead's Avatar
Mark Shead
Mike why would yellows be any better for mpg aks Rod about his .
Mark
Old Sep 7, 2004 | 05:25 PM
Andreas's Avatar
Andreas
I must admit im jealous of the offer Phil got, try SECS free for 3 months and if you dont like it, return it.
Old Sep 7, 2004 | 05:27 PM
Mike Rainbird
Caraholic
Mark,
The fact that some power may be gained by moving the bigger injectors to the back of the plenum for high speed use and then better atomisation for low speed use of the smaller injectors... .
Old Sep 7, 2004 | 05:32 PM
Mark Shead's Avatar
Mark Shead
Mike I havent done a back to back on moving Injectors to rear of plenum but Rods engine doesnt have a problem with Either Power or Mpg,
I have mapped engines with WRC inlet and standard fuel Inj position and there is no benafit other than Selling 8inj and WRC inlet the clever person keeps his money in his pocket .
Mark
ADUSR33's Avatar
ADUSR33
good luck phil ....by the way lovely rottys ..im after a puppy myself
Old Sep 7, 2004 | 06:01 PM
markk's Avatar
markk
Ima-Racing500,
errrmmmm NO
neither of you will be getting secs on friday !!
Old Sep 8, 2004 | 02:15 AM
RANJ's Avatar
RANJ
coont, any person visits u doesnt keep money in there bank accounts never mind pockets
i only came for a basic rebuild
Old Sep 8, 2004 | 07:35 PM
ECU Monitor Enthusiast
markk, This has a certain ring of IRONY to this as YOU will find out very soon
Old Sep 8, 2004 | 08:46 PM
markk's Avatar
markk
SECS,
maybe so
Old Sep 8, 2004 | 08:49 PM
Thrush's Avatar
Thrush
Irritating c........
Phil - FFS why not just stop acting the twat and CONSTANTLY posting about it? Give the man a break rather than constantly trying to ridicule the guy Getting really boring now fella
Old Sep 9, 2004 | 02:39 PM
Old Sep 9, 2004 | 02:50 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
D DAY tomorow then
Old Sep 9, 2004 | 02:52 PM
Old Sep 9, 2004 | 02:53 PM
Rs Gus's Avatar
Rs Gus
Originally Posted by SECS
simon i hope people will not be doing that to u tomorow!!!!!!
Old Sep 9, 2004 | 02:57 PM
dumped's Avatar
dumped
Could somebody please take their big power 4 injector car upto 175mph odd the short one injector intermittantly as if its failing then turn it off and let me see the safe results?
Old Sep 9, 2004 | 03:05 PM
The SECS S8 ecu will NOT drive an injector unless it detects a resistance just before a pulse is sent to it.
So provided the intermittent problem is electrical then 99% of faults
like this can be safely detected.
A fault code will be registered and that whole faulty cylinder will be
shut down to prevent such a situation arising.
Motec does this too, dont know about Autronic or Pectel T2/T6 but Weber
ecus do NOT.
Non electrical faults such as low fuel pressure/block injector are a little
harder to detect unless the failure significantly upsets fuel flow
causing a lambda sensor lean condition but then lambda sensors
only read the average of ALL cylinders.
Old Sep 9, 2004 | 03:07 PM
dumped,
SECS,
This ones for you Mart..
Old Sep 9, 2004 | 03:13 PM
dumped's Avatar
dumped
Good feature Just dont go for this 4 is super safe ace no matter what thing just dont sit right.
Old Sep 9, 2004 | 03:16 PM
dumped, There are no absolute guarantees in cars, electronics or life for that matter.
(Except we all die eventually )
Old Sep 9, 2004 | 03:19 PM
St3V3_C's Avatar
St3V3_C
And you can bet there is more than one person working on a cure for that as we speak
dumped's Avatar
dumped
So fuel pressure prob is same outcome which leaves blocked injector being the only higher risk of 8 vs 4. I would try 8 to see if you could get more power but mikes wife's tales are always wrong so probably not worth it LOL
In my head even with closed loop lambda I still feel smaller injectors can only be better for low speed running etc - whether its worth it on a tuned engine etc who knows for its purpose etc
I have 8 as they injectors were free and not had a problem in the past.
Old Sep 9, 2004 | 03:36 PM
8 injectors are used for 3 reasons......
1) BLING EFFECT
2) 8 LOW FLOW CHEAP INJECTORS CAN BE USED AS EARLY SHONKY SOFTWARE
COULD NOT DRIVE GREYS PROPERLY .
3) USING EXTRA 4 INJECTORS GIVES BETTER MIXTURE FORMATION DUE TO MORE TIME TO
MIX WITH AIR AS IT IS FURTHER AWAY FROM THE CYLINDER.
THIS DOES GIVE A SLIGHT INCREASE IN BHP (perhaps 5-8 BHP in 500 BHP)
The disadvantages.....
More cost, more electronics, more wiring, more software, more fuel lines and less space under the bonnet.
I personally prefer the BIG 4 route but, 8 injectors are just as effective if set up
properly.
Old Sep 10, 2004 | 06:40 AM
Jokeri's Avatar
Jokeri
Well?, any news yet?
Old Sep 10, 2004 | 08:23 AM
Yes.
https://passionford.com/forum/viewtopic.php?t=72070
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
pabloXR
Sep 21, 2015 12:42 PM
Bailes1992
Sep 3, 2015 02:17 PM
ProjectBobcat
Was It You?
Aug 29, 2015 03:08 PM
