More torque....????
Old Jan 30, 2007 | 05:28 PM
  #41
jammy86's Avatar
jammy86
Rasing the compression ratio (adding more boost) is what increases both torque as it increases the BMEP (pressure) on the pistons. larger diameter pistons give larger torque for the same BMEP. This is ignoring anything to do with electronics, or cam-timing (dynamic CR)
Power = Toque x Velocity(angular). If you keep the same torque throughout the rev range you will get a straight line for the power. and so if you raise the revs but keep the torque the same (not normally possible) the you'll have more power. likewise if you keep the revs the same, but increase the torque, you'll have more power.
JAmes.
Old Jan 30, 2007 | 05:45 PM
  #42
big_wig_074's Avatar
big_wig_074
Originally Posted by jammy86
Rasing the compression ratio (adding more boost) .
theyre not the same thing are they?
Old Jan 30, 2007 | 05:50 PM
  #43
jammy86's Avatar
jammy86
yup they are, more or less. since the gas is pressurised before it gets a squeeze by the piston your raising the max pressure before ignition. This has the effect of increasing the volumetric efficency, following to the OTTO cycle.
I think its about 3.74psi of boost increases the CR by 1. (might be 3.47)
JAmes
Old Jan 30, 2007 | 06:00 PM
  #44
bud-weis's Avatar
bud-weis
Football Cwazy
Originally Posted by madevelopments
Western performance have a Dyno Dynamic RR, I have just run on Surrey RR one with a Escort Cos making 394hp and 390ftlb at the wheels which worked out with the Subaru trans losses 504hp and 490ftlb at the fly which is very close to what these engines make on the engine dyno
Mark
correctomundo defo the best i've used yet...and the figures are very very beleivable,exactly as you'd expect if you know what your looking at
they also do Autronic don't they.......
Old Jan 30, 2007 | 06:02 PM
  #45
foreigneRS's Avatar
foreigneRS
Testing the future
you can't just run more boost with the same turbo forever though, it will become inefficient
Old Jan 30, 2007 | 06:25 PM
  #46
lead_foot's Avatar
lead_foot
is awesome
Boost will just end up being seen as the engine's reluctance to flow.
