Roll Cage Camera Mounts
Old Jan 18, 2007 | 12:18 PM
John Laverick's Avatar
John Laverick
Default Roll Cage Camera Mounts
Hi guys,
I want to purchase a roll-cage camera mount for this years track days...I have a Canon Ixus 60 Camera [with 2GB memory:
http://www.canon.co.uk/For_Home/Prod...S_60/index.asp
And I'm looking at buying this mount:
https://sslrelay.com/www.fastfilmssh...dex.shopscript
EZ mount 2.2 cm to 2.85cm
https://sslrelay.com/www.fastfilmssh...51_346x259.jpg
https://sslrelay.com/www.fastfilmssh...50_346x259.jpg
Just wondered if the mounting stud is an industry standard for all cameras etc.. [diameter and pitch]?
Will I see decent results using this set-up?
Old Jan 18, 2007 | 01:25 PM
ando4i's Avatar
ando4i
HI
Yes the thread is the same for all video cameras and still cameras 1/4" thread or something.
You will see an improvment in the pics that you will get from your camera as it will be fixed and not hand held.
Are you using it to do Stills or will you be putting it in Video mode? If you do Video I would suggest you get a bullet camera set up.
I can Highly reccomend FastFilms, I use there Bullet cameras and suction mounts on the out side of mine and my mates cars.
HTH
Mark.
Old Jan 18, 2007 | 02:39 PM
John Laverick
Originally Posted by ando4i
HI
HTH
Mark.
I want to take videos not pictures...
If I went for the bullet cam is it just a case of ensuring my camera has the correct input capacity and then mounting it etc... What about sound?
Is a 2GB card going to get me very far?
Old Jan 18, 2007 | 03:49 PM
ando4i's Avatar
ando4i
Hi John
What quality do you ultimatley want? if its watching on DVD on a 42" tv, Then I would go for a Bullet camera with 520TVL, Fast Films do a kit, its what I use, and you get everything you need, Camera, Mic, Battery Holder that takes 8 AA, and all leads and connectors. Then you either need a Video Camera with AV IN so you can use that as a recorder, I use a sony Mini DV. this is the best quality way to do it, but you can get Solid State Recorders that are good( The PDR100 that they do is nearly as good as Mini DV) if you want to do stuff for the net eg, YouTube, these are good as the footage will be already digitised and you don't have to upload it in realtime as you do Mini DV, there are differant ones but the MobiBox that FF do is good you put an SD Memory card in it and for every Gig you have of Memory you get 30 mins at high Quality. The bullet camers connect straight to it and it records sound as well.
If you want to capture video on track days tbh I don't think you'll get very good results from a digi still cam in video mode, but if you get the roll cage mount at least you can use it with either the Digi Still Cam or a Bullet Cam if you get one in the future, so it won't be money wasted.
Hth
Mark.
Old Jan 19, 2007 | 07:57 AM
John Laverick
Hi John
Hth
Mark.
Thanks for the reply......I'm not bothered about recording DVD quality footage...its just for recording laps at track days to watch on the computer afterwards and laugh at my driving
I was very impressed with the quality of footage the Canon took in Video mode so I think it might be worth a go......or may be just stick to the home made porn
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
Mikersturbo
Sep 27, 2015 07:43 PM
DavidK
Sep 27, 2015 02:55 PM
