my alternator is charging 16 volts
Old 16-01-2007 | 08:28 PM
abdr500's Avatar
abdr500
Default my alternator is charging 16 volts
my alternator is charging 16 volts could this be the regulator and wht casue them to go as the alternator is about 6 month old from new battery whent dead and i left it for 2 weeks started and 16volts
Old 16-01-2007 | 08:30 PM
phil4x4saph's Avatar
phil4x4saph
16volts? Its fucked!
Sorry if thats a bit brief!
Old 16-01-2007 | 08:33 PM
St3V3_C's Avatar
St3V3_C
Is your meter reading right?
Old 16-01-2007 | 08:36 PM
abdr500's Avatar
abdr500
St3V3_C
yes as i have the one on my turbo timer and the one that come with the escort cosworth and i just tested it with a multymeter its got to be regulator
Old 16-01-2007 | 08:44 PM
RichieST's Avatar
RichieST
i'm pretty sure a dry cell in a battery can cause the alternator to kick out too much juice (but i may be wrong). Could be worth getting another battery to stick on to see if its still doing it??
Old 16-01-2007 | 08:57 PM
rapidcossie's Avatar
rapidcossie
a healthy battery should be charging more than the 12v.
mines is about 15.
Old 16-01-2007 | 09:13 PM
abdr500's Avatar
abdr500
well my battery is shit as it goes dead in 1 week if left plus i had left it 2weekd flat totaly will go now and cheack if the battery is dry but could this realy cause :? a low battery
Old 16-01-2007 | 09:14 PM
abdr500's Avatar
abdr500
well my battery is shit as it goes dead in 1 week if left plus i had left it 2weeks flat will go now and cheack if the battery is dry but could this realy cause it a low battery
Old 16-01-2007 | 09:44 PM
Alan s1's Avatar
Alan s1
Should'nt it only be around 14volts with every thing turn on ie light fans ect ect But if the battery keep loing charge then its probly best to change it and see whot volts its running
Old 16-01-2007 | 10:01 PM
DazC's Avatar
DazC
Your battery could be shit because your alternator has cooked it!!! Usually a fooked battery will only provoke up to around 14.5v, not 16.
Old 16-01-2007 | 10:05 PM
Ade's Avatar
Ade
Fast Ford snapper
Alternators can overcharge, which then leads to your battery getting fried!
Take it to a garage or a decent spares shop to get it double checked if you're not sure... should be mid to high 13's really.
Old 16-01-2007 | 10:16 PM
abdr500's Avatar
abdr500
right every one has got the wrong end of the stick I run my own garage so I am not stupid just asking if the regulator on the alternator is fooked and causing it to give out 16v as it use to be 14v thanks anways
Old 16-01-2007 | 10:22 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
sounds like a alternator regulator problem to me....
Old 16-01-2007 | 10:24 PM
abdr500's Avatar
abdr500
JTECHSAFF
thank you thats what i have been saying
Old 16-01-2007 | 10:29 PM
JTECH James
Passion for Fords!
the internals of the alternator are obviously working well, but the regulator isnt controling the amount of charge being produced , this is probably what killed the battery in the first place...
Old 16-01-2007 | 10:54 PM
phill2400's Avatar
phill2400
Sounds like the diode pack on the back of the alt change that first they are only about 12 quid.
Old 16-01-2007 | 11:04 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
I had this once - 6years ago infact...unfortunately I did completely the wrong thing & ignored it thinking it was ok - it fried my battery, ECU & headunit in the process!!!!
jonfoc
16
11-09-2018 06:35 PM
01-11-2015 07:53 PM
jay030787
18-09-2015 05:38 PM
Cos500
16-09-2015 10:50 PM
morg65
Escort MK 5 / MK 6
11-09-2015 02:55 PM
