how do i stop program starting when opening windows?
Old Jan 13, 2007 | 10:29 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default how do i stop program starting when opening windows?
when i start my computer 1001 programs open up i know u delete them froma startp menu but cant rememebr how u get on it?any help
Old Jan 13, 2007 | 10:32 AM
Redkop's Avatar
Redkop
Start>Settings>Taskbar and Start Menu
Old Jan 13, 2007 | 10:35 AM
JjCoDeX75's Avatar
JjCoDeX75
And if this fails, go to Start/Run and type in 'msconfig'
The very right most tab shows you what loads up each time you start your computer. OFten useful little tool for removing bits and pieces!
JJ
Old Jan 13, 2007 | 12:26 PM
_DAN_'s Avatar
_DAN_
Yoon
Dowload CCleaner,then use the option in tools for startup.
Do a prntscreeen before you delete anything tho.
Old Jan 13, 2007 | 04:20 PM
Wardy257's Avatar
Wardy257
Google a program called 'autoruns' and download. It works a treat.
Old Jan 13, 2007 | 05:46 PM
Jasesapphy's Avatar
Jasesapphy
Msconfig in the run box, go to selective start up and uncheck
Old Jan 13, 2007 | 05:49 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
if you are disabling services you should always use 'services.msc' and never disable them through msconfig
Old Jan 13, 2007 | 05:51 PM
jammy86's Avatar
jammy86
Under start>run>MSconfig theres also a services tab. click that then click 'hide all microsoft services'
This will show up any services (not quite the same as programs) that might be running. If there is crap in there for your printer, or mobile phone, or an old virus scanner you dont use anymore, turn them off BUT only if you DONT use them anymore.
If you turn them off and it turns out you still use them you can always turn them back on.
hth
JAmes
Fordmad!
Sep 26, 2015 05:24 PM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
