mad vibrations in the steering wheel , help
right peopel im gettin real bad vibrations in the steering wheel after i crashed me honda civic , its had new shock , top mount lower arm , hub , drive sharft , brake and disk , also put it on steelys and still gettin it , its not bad before 3k and then its bad after that and real bad on vtec , when i crashed i hit the front wheel do you think i could have fucked the engine monts and this is what is makin it shake like mad? all help needed as i need the car for work tusday lol ,
thanks
thanks
Team HOTHOT!
as Luke has said, it is related to engine speed, and not road speed. I'd be checking the gearbox mounts and engine mounts, as the engine may have shifted and be resting on the chassis or body.
Also check the chassis member on that side that it has not been pushed into the engine compartment and is sitting on the engine (you'll need a jig to sort this if it is)
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Fudgey
17-09-2015 01:06 PM
Adam Graham
06-09-2015 06:04 AM
