help needed
Old Dec 26, 2006 | 09:47 AM
gus's Avatar
gus
Default help needed
right my dad has one of them semi automatic type fiesta's
(where you can swith between manual and automatic)
problem is it will not start off the key
plenty life in battery, starter is fine (when it engages) just sometimes it will not start, other times its fine
the car is booked into fords but we cant start it to get it there cant tow it as its automatic
is there a way of starting by by-passing the ignition altogether (hot wire)
just so we can get it moving
thanks in advance
gus
Old Dec 26, 2006 | 10:09 AM
gup's Avatar
gup
put the ignition on and bridge the starter over also check the black connecter inside the bottom coloum cover as the multplug for the ignition plays up with a bit of dirt hope this helps also when trying to start the car wiggle the gearstick in park or neutral and c if this helps while turning the key over
Old Dec 26, 2006 | 10:23 AM
St3V3_C's Avatar
St3V3_C
How far is it? Check the book, but if you go slowly for a short distance, towing is usually OK.
Can Ford come and get it? Or the AA/RAC/whatever?
Old Dec 26, 2006 | 10:58 AM
jonnyboy's Avatar
jonnyboy
sounds exactly the same problem as my m8s 03 plate fiesta, got it to frauds and charged him 350 quid to supply and fit a new gear selector motor. common problem on fiesta apparently(sp).
the car had only done 28k...
Old Dec 26, 2006 | 11:17 AM
gus's Avatar
gus
cheers chaps
what wires do bridge on starter?
will check multi plug then it looks like gear selector then
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
