WTF is a boost pot
19-12-2006 | 04:33 PM
WTF is a boost pot
Any clues as i've just been asked if my car has one.
19-12-2006 | 04:35 PM
its a knob which you use to set boost levels
19-12-2006 | 04:36 PM
It's a 10 or 12 position (usually) knob to set the boost level, needs to be mapped for it. Pot' as in potentiometer.
19-12-2006 | 04:38 PM
12 position boost control - 1.0 to 2.2 bar on my car.
19-12-2006 | 04:51 PM
what should you set the wastegate bar to when using this system? lowest on the threads?
19-12-2006 | 04:58 PM
Do they only work with Air Injectors?
19-12-2006 | 04:59 PM
you set it to half a hole preload normally
you could get it to work with an amal valve but most people use them with air injectors
19-12-2006 | 05:08 PM
air injectors with mine anyway
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
Minirotty
11
15-09-2015 10:16 PM
