Skyline engine probs...
Old Dec 11, 2006 | 03:32 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default Skyline engine probs...
some of you will will remember from jap fest when my mate gave me the keys to his liner and let me loose in it round combe
but failed to tell me that he had put a stage 2 turbo on, a welding tip inline with the actuator to increase boost and the fact that the top end was rattling...
anyhow that little lot resulted in one dead engine
i got him a deal on some .05mm oversize pistons, and got all the machine work carried out etc.
he rebuilt it and we then put it back in the car.
this was in october.
anyway, i rang him today to see how it was going...
he has done 110 miles of running it it so far, and had it MOT'd
now monday morning last week, he was drving down the motorway doing 60mph he tells me as he has not driven any faster than that while running it in.
anyway, it cut out on him and he couldnt restart it. it ran perfectly before that
he says he has done a compression test on it, thy cylinder nearest the bulkhead has 100 odd psi, the rest have around 30psi
i dont know what the fook is wrong, i told him to chack the cam timing on it before doing anything else.
his dad reckons it cold be the rings? could this be the case?
he said there was NO smoke when it cut out, so i dont think its that tbh, but not got any other ideas really other than the timing.
we didnt check the head tho when it was apart, as the ring lands had broke off of 4 out of 6 pistons so we kind of gathered it was that which was fucked.
does anyone have any ideas of what it could be?
he still owes me £400 for the pistons
Old Dec 11, 2006 | 03:34 PM
Dan Cossie's Avatar
Dan Cossie
Jap Cars relaible hey
Old Dec 11, 2006 | 03:41 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
no idea fella but can sell ya an emgine from a r33 gts if ya want one
Old Dec 11, 2006 | 03:42 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
how much mate?
Old Dec 11, 2006 | 03:46 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Why would 5 out of 6 piston rings fail?
Headgasket surely.
Why/how that would happen without either detting its tits off or whatever is beyond me though.
Bearing in mind RB25s are mega reliable and standard ones can knock out 500bhp+ with good reliability when set up right, something is very wrong there.
Old Dec 11, 2006 | 03:49 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
he built it - that could be the answer
but for it to do 110 miles then die....
buggered if i know
Old Dec 11, 2006 | 03:51 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ill get the compressor out and try pressurising the cylinders
chip gave me some good advice to try before taking apart
Old Dec 11, 2006 | 03:56 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
maybe he did the head bolts up with his fingers
Old Dec 11, 2006 | 04:02 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
was thinking that too.
i know on some engines that you need to re-torque them after a bit.
is this the case with skylines?
Old Dec 11, 2006 | 04:07 PM
furry's Avatar
furry
£750, tis a 63k from new engine, standdard car that has just had cambelt and set up by abbey motorsport. in swindon fella
Old Dec 11, 2006 | 04:10 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
nice one mate, ill see what he says.
he still ows 400 for the pistons tho
Old Dec 11, 2006 | 06:39 PM
PeterLucas's Avatar
PeterLucas
What about jumped cambelt tooth, bent valves hence no compression. Would explain why its on all cylinders!
Old Dec 11, 2006 | 06:43 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
next step is try a cylinder leakage test, ive got the kit here if you want to travel to devon to pick it up
Old Dec 11, 2006 | 06:44 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
which was the first thig i said about checking the cam timing.
but there is 30psi on em, if the valves were bent, then there would be fook all
Old Dec 11, 2006 | 06:46 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
JTECHSAFF
cheers mate, i have a compressor so ill try and hook that up and see what i can find...
Old Dec 11, 2006 | 06:52 PM
JTECH James
Passion for Fords!
turn the cylinder being tested onto compression so all the valves are shut ,and listen for where the air escapes, it may be the breather system if its rings, or throttle body for inlet valves, or exhaust for exhaust valves. take the plug out next door and see if that sees any pressure as it may be haed gasket ,but watch out it isnt leaking into that cylinder through a manifold! check if the coolant tank sees any pressure ,
loads of test to do that way , my kit shows a percentage of cylinder loss ,so you know how much is leaking.....
Old Dec 11, 2006 | 06:57 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
cool
cheers mate
ill try and get over his this w/e
mgtkr1
107
Dec 6, 2016 04:23 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
