T35-T34 WHATS THE DIFFERENCE
Old Dec 9, 2006 | 09:01 PM
NUNOOKS's Avatar
NUNOOKS
Default T35-T34 WHATS THE DIFFERENCE
HI THERE CAN ANY BODY TELL ME IF THESE TURBOS ARE THE SAME OR DIFFERENT, IF DIFFERENT WHATS DIFFERENT ABOUT THEM, AS MY CAR RUNS A T35 AND I ALWAYS THOUGHT THEY WERE THE SAME , THANKS.
Old Dec 9, 2006 | 09:03 PM
Jim Galbally's Avatar
Jim Galbally
T34 is the turbo from an escort cossie
T35 is the turbo from some kind of scannia truck
most people refer to the T34 as a T35, hence the confusion. 99% of the time when people say T35 when talking about cossies, theyre really talking about T34s
i beleive jano was selling real T35 turbos at some point for fitting to fords too which confused things even more
Old Dec 9, 2006 | 09:12 PM
NUNOOKS's Avatar
NUNOOKS
I BORUGHT MY TURBO FROM TURBOTECHNICS ITS A T35 STG2 SURELY ITS NOT A TRUCK TURBO AS THEY NEW IT WAS FOR A COSWORTH.
Old Dec 9, 2006 | 09:13 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
T35 is a T34 with a .63 ex housing
T34 is .48 or .55 ex housing.
Old Dec 9, 2006 | 09:17 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i think Turbo Technics stg2 or stg3 turbo is fitted with the .55 housing and they call it a t35.
Old Dec 9, 2006 | 09:20 PM
Rick's Avatar
Rick
no its not. T34 is std on escos and is .63
Old Dec 9, 2006 | 09:21 PM
NUNOOKS's Avatar
NUNOOKS
THANKS PEOPLE THESE TURBOS CAN GET A BIT CONFUSING
Old Dec 9, 2006 | 09:23 PM
JTECH James
Passion for Fords!
thats why people call the esc cos turbo a t35,
i think a true T34 ,is a T34 size compressor and a .48 ex housing ,anything else can be called a T35, Or if they want to call it a T34 they can
Old Dec 9, 2006 | 09:27 PM
SS1's Avatar
SS1
so whats a
T34.63 Hybrid Turbocharger with Garrett -34 Actuator
is that a higher spec again .?????
Old Dec 9, 2006 | 09:29 PM
JTECH James
Passion for Fords!
A T35 with different spec internals ,ie cut back blades. with a -34
Old Dec 9, 2006 | 09:31 PM
SS1's Avatar
SS1
JTECHSAFF
ive got one just pondering was it a higher spec
maybe somebody will know later on
Old Dec 9, 2006 | 09:35 PM
JTECH James
Passion for Fords!
Originally Posted by avid-fan
JTECHSAFF
whats to find out? its a T34 compressor housing, with a .63 ex housing, commonly called a T35, modified to make it a hybrid spec, ony the people who modified it can tell you why/ how it was modified and supply you with a compressor map to get a chip spec'd. And its runnng a -34 actuator.
Old Dec 9, 2006 | 09:37 PM
_DAN_'s Avatar
_DAN_
Yoon
Wasn't the .55 housing a Ford WRC one?
I'm bored hence my query.
Rippers's Avatar
Rippers
Monte Geek
IIRC T34 and T35 are the same thing..
Old Dec 9, 2006 | 09:38 PM
JTECH James
Passion for Fords!
aint got a clue
not that common though are they
Old Dec 9, 2006 | 09:39 PM
_DAN_'s Avatar
_DAN_
Yoon
They are mate,just people call the .63 EsCos items T35s.
Old Dec 9, 2006 | 09:40 PM
JTECH James
Passion for Fords!
same compressor housing and compressor, but dependant on exhaust housing.
i hope/think im right!
SS1's Avatar
SS1
JTECHSAFF
fank you now i understand
Old Dec 9, 2006 | 09:42 PM
Rippers's Avatar
Rippers
Monte Geek
Same thing as in I Say Tomayto, You Say Tomahto
Old Dec 9, 2006 | 09:43 PM
JTECH James
Passion for Fords!
so then, what about a T38, some of them run modified T34 compressor housings
Old Dec 9, 2006 | 09:48 PM
Rippers's Avatar
Rippers
Monte Geek
IIRC a T38 can be either a T34 with a bored out T34 compressor housing or a T34 with a T4 compressor housing depending on the manufacture
Old Dec 9, 2006 | 09:49 PM
JTECH James
Passion for Fords!
i think you may be right....
Old Dec 9, 2006 | 09:50 PM
Originally Posted by Shakespear
A T34 by any other name, does it not still boost just as sweet?
Anything you hear referred to as a T34 or a T35 for a cossie is all the same thing.
Old Dec 9, 2006 | 09:51 PM
UT38 is the bored out one.
Old Dec 9, 2006 | 10:42 PM
Jim Galbally
as this thread has proven, different people think it means a different thing, so the best advice?
JUST ASSUME EVERYONE IS WRONG
Old Dec 9, 2006 | 11:20 PM
BigErn's Avatar
BigErn
So whats mine then? Got a reciept with the car for a GpA T36
Old Dec 10, 2006 | 10:25 AM
Jim Galbally
depends what company sold it to you :P
also im pretty sure that the "grpA" bit's made up
Old Dec 10, 2006 | 10:32 AM
Nash's Avatar
Nash
Cake lover!
Just a thought wouldn't it have made sense to give them all different numbers etc:
T34=.48 ex T34=.48 ex
T35=.55 ex T34.5=.55 ex
T36=.63 ex T35=.63 ex
Such an off the wall idea i know but would have made stuff alot easier if they had thought about it in the begining. For gods sake no one put this idea into practice as would make it even more confusing.
Old Dec 10, 2006 | 03:20 PM
JjCoDeX75's Avatar
JjCoDeX75
Just to add to the mix, I have a Turbo Technics Staqe 3 T35, which I have been advised has a 0.48 rear housing!
JJ
Old Dec 10, 2006 | 03:29 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Oh dear Lets clear it up a bit.
T34 comes from the fact that the rear housing is a T3 flanged one, and the front housing is a small T4 one, ie its a T3/4 (an RS500 is a T3/4 actually too, jus a bigger one).
T35 and T38 are TBH more real terms as basically that just gives an estimation on size, ie more than a T3, but not a T4.
Same as T2s, T25s, and T28s, its the way they name general turbo sizes.
There are still hundreds of variations of each of the above though.
So to sum up, an EscCos turbo is a T35, which is a T3/4 turbo.
Old Dec 10, 2006 | 03:34 PM
badboy rs's Avatar
badboy rs
i think we need the experts like stu and christian to comment on this subject
Old Dec 10, 2006 | 03:36 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Why? I just gave you the answer...
Old Dec 10, 2006 | 03:39 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Here is a real T35 :
Old Dec 10, 2006 | 03:41 PM
JjCoDeX75's Avatar
JjCoDeX75
This answer I would agree with - This was my understanding as well!
JJ
Old Dec 12, 2006 | 09:07 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
None of you have given the right info on the T35 type Turbo's as you dont understand what the difference is.
A T34 is the Esc Cos large Turbo. The Exhaust housing makes no diff to this. It could have a .36 .48 .55 .63 etc.. and it will still be a T34 Turbo.!!!
A T35 has a different compressor wheel and housing to the above unit. It flows exactly the same amount as the T34 but has less lag time due to the shape and design of the housing and wheel. This is the reason that i use this type Turbo on my conversions and some engines which would suit this size turbo.
If you want more info there is a thread on my site which shows pictures of the items and results on a car which has been tested with 3 different types of turbo's
T34 - T35 - and a 4x4 Cosworth Unit.
The results and graph speak for themselfs
Regards
Jano
Old Dec 12, 2006 | 09:38 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
What? I know you know a lot Jano, but thats bollocks
T35 means next to nothing, just a general name for a range or turbos, or in the case you seem to be describing its the same as Turbo Dynamics call their garrett turbos TD48943487 etc etc, means nothing, just what ONE company calls their specific turbo.
Go to Garrett or any of the proper turbo manufacturers and ask for a T35, see what you get...
You get a "which type, there are hundreds of different specs you clown" answer, but the chances of getting this turbo you describe are fuck all.
Old Dec 12, 2006 | 09:53 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
so whats my turbo then? i always called it a T35 lol
its got a maram shaft, inlet says .60 on it and the zorst housing says .63 lol
it confuses the fuck outta me
it also has this, whick im told is where the wrc cars would use a speed sensor?
Old Dec 12, 2006 | 10:12 AM
Jay,'s Avatar
Jay,
Sponsor
i always yhought a t35 is nick name for a hybrid t34 like 360 bearing ect
Old Dec 12, 2006 | 10:36 AM
Ginge !'s Avatar
Ginge !
just finding my feet
a REAL T35 made by garrett is a fucking truck turbo
the rest are just nick names people use to make out there turbos are "bigger and better",,,,,,, they usually have grpA added to them for a extra hundred quid and im guessing the bloke with the grpAT36 paied the most for his turbo,,, may have a roller bearing in it,,,,,,, BUT I FUCKING DOUBT IT
so to summerise the REAL term for a cossie T35 is a T34 and then look at the spec
and a stage 3 T34 with a .48 housing ,,,, id like to know what the 3 stages of mods are on that,,, guessing naming it was stage 3
Old Dec 12, 2006 | 10:52 AM
Jay,'s Avatar
Jay,
Sponsor
ginge i love ur replies
