WILL 16" COMPOMOTIVE MO`S GO OVER 330 AP 4 POTS
I have 17" MOs and 330 mm AP 4pots (CP5200) there is quite a bit of rim clearance, in fact i'm 100% sure you can get 356mm discs behind the 17's.
I'm sure you can fit 16" MOs over my brakes as well.
Christian does have 330mm brakes under 16" wheels but i seem to recall he had to modify the calipers a little to fit them behind his wheels.
Will have to ask him what difference there is between his wheels and a set of MO's and what he had to do to the calipers
Originally Posted by JTECHSAFF
si b runs comp brake 330mm brakes and 17" comp mo's and you cant get a fag paper betwwen the caliper and wheel....
the bloke looked at the wheels and brakes and said ...
fook me ive never seen Calipers that close on a car before
so i carnt really see how 16s would fit tbh..i may be wrong"i normally am"
The other thing people aren't taking into account is the actual calipers. I know my CP5200's will fit behind 16" Comp MO's. I can take pictures and measurements if they are needed.
Minirotty
11
15-09-2015 10:16 PM
