cvh 'modified' valve stem seals???
I need to change the stem seals on my car.
I know theres two types (one with a washer plate thing and one without)
but ive seen some advertised by PJ motorsport saying modified stem seals (£19.99)
any idea what they are?
do ford still do both types of seal and anyone have an approx price or can explain which applications have which type of seal?
cam fitted is supposed to be a piper t2 so not sure if I need a different type due to the springs or anything?
cheers
cheers
how much do you want for them matt? are they new and of the one piece type?
BTTT for more info about why they were modified and what they did this on?
the ford parts list the washers and seals separate?
do you know which one?
and is it best to run the 'modified' ones? or the ford ones?
PS - jesse do you have any of your info and things on your cars on a website? you only have your picture on the link? just wondering as Know youve doen many impressive things with your cars.
mark- But I dont know which IS the new type of which is the type I should have??!
I take it separate washer and seal are the new ones??
are these poorer to use or something?
Hi Melv
The ones ive got are the later ones, and they have always been like this from ford and i my opinion are the better type, However you will find that if you buy from a Motor Factor they will come in two pieces. Also i have noticed that when people have changed the seal to later ones they have left the washer part in the head and placed the complete stem seal on top
Regards Matt
Regards Matt
if you have the old 2 piece ones and replace with top hat type THROW away the washers that will be left on the head. they normally dont fit over the old washers anyway which tells you theres a prob.
The old type seals are OKish for N/A aplications, but they get blown loose easily in turbo engine. Ford changed the type to the newer one piece type a LONG time ago but the two piece type still lives in other spare part shops.
Sorry, I don't have any gathered information of my car in the internet, but I'll be happy to answer if you have any questions. Also the picture is years old. I'm also building a non original S1 with the same management that I have found excellent. Rough spec:
DIY Megasquirt engine management with MS'n'EDIS code update.
DIY mapped fuelling and ignition
DIY ported efi cylinder head
Mondeo EDIS wasted-spark ignition, with multispark option.
DIY built wideband controller
S1 bottom end
mk5 Escort flywheel, inlet, throttle setup and head
GRS S1 intercooler with twin kenlowes
Magnex exhaust
Kent CVH 35 cam
Motocraft 071 plugs
DIY ecu controlled boost control
DIY hybrid gearbox
2.5bar MAP
Bosch greens
Knock sensing
All sort of gadgets...
S1 bottom end
Magnex exhaust
Kent CVH 35 cam
Motocraft 071 plugs
DIY hybrid gearbox
2.5bar MAP
Bosch greens
Knock sensing
Originally Posted by Neil S
Just get the 'top hat' type from ford - you'll be fine, and Im sure theyre much cheaper than 20 quid
Dont drop the collets in the sump
Neil.
Neil.
oh yeah... rocker cover gasket! think its first time ive bought a geniune one? they have little metal dowels in them to stop excess clamping I think!! well cool. the motorfactor ones dont and mine usually leak!! lol
my next post will be.... will a collet do much damage if i just leave it rattling around!!
oh damn... think someones half inched my skyes compressor thing? anyone know if can get one cheaper than £14??
My girlfriends fiesta had one in there for about a year lol
I shit myself when i dropped it down the oilway
Neil.
are the alloy sumps still magnetic?
grrr just started the thing up...started good but its breathing pretty heavy and smoking at idle! no doubt its fair fooked!!
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
