3D00R REBUILD
3D00R REBUILD
Considering rebuilding my 3 door after Christmas. What are the best bits to get.
Just want to strenghen engine as its running stage 3 now
Get some new +50 4x4 pistons and bore the block to suit,these have an offset gudgeon pin which stops all the piston slap from cold associated with early cossie motors and will also drop the comp ratio slightly to 7.8:1...
New oil pump is a must and get the crank checked for wear and ovality and grind it if required......build it all up with new shells etc and bobs your uncle........one motor perfect for stage 3....
Any ideas where i can get some of the parts you mentioned.
He`s not doing the car till end of Janurary so it will give me time to get Xmas out the way & get some parts
He`s not doing the car till end of Janurary, so it will give me time to get Xmas out the way & get some parts
makes it sound easy like playing with lego nice one mr diva
It is isn`t it..
You could always give Butch a ring Macker,he can do it with his eyes shut..
And in case anything goes wrong,there`s always customer service Dan..
"Er mate.............We`ve got a little issue with the car"..
the key to engine building is not just in the parts you need, but also in the way they are fitted and the clearances used!
cleanlyness is paramount
It is isn`t it..
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
