What should a boost gauge read at idle?
Old Nov 29, 2006 | 11:24 AM
Rob84's Avatar
Rob84
Default What should a boost gauge read at idle?
On a typically standard turbo'd car. I understand there will be a differences from car to car.
A friend's boost guage is showing -18psi on his VX220 Turbo and the only addition is a milltek turbo back system with standard cat.
he thought it was a bit low and he was getting answers of "it should be at 0 on idle" on the VX forums so I thought i'd ask on here
any help will be much appreciated
Old Nov 29, 2006 | 11:26 AM
AndyBrew's Avatar
AndyBrew
I'm no expert but I'm pretty sure a boost gauge will only read ZERO when the engine is turned off.
at idle my blitz boost gauge reads -0.42 ish depending on the air temp.
Old Nov 29, 2006 | 11:29 AM
cahzz's Avatar
cahzz
only way you guna get boost on idle is by having anti-lag, sure you wasnt reading vacuum
GARETH T's Avatar
GARETH T
if it shows -18 psi,,, your friend has just broken some laws of physics
Old Nov 29, 2006 | 11:30 AM
scottbrown's Avatar
scottbrown
will only read zero at idle if he has anti lag
-18 is normal for a turbo car as long as the gauge goes into the plus when he comes on boost. at idle it is measuring vacum
Old Nov 29, 2006 | 11:33 AM
Andreas's Avatar
Andreas
No way that -18 psi is normal, you wont ever see that, even when coasting down or whatever the english word is for when you let off the throttle.
Old Nov 29, 2006 | 11:34 AM
GARETH T's Avatar
GARETH T
you wouldnt see -18 if the engine was idling in deap space dude
Old Nov 29, 2006 | 11:35 AM
Rob84's Avatar
Rob84
Ok ok, I know enough about engines to know that without antilag, a turbo'd car will never show a positive boost pressure. I guess I just worded the initial post wrongly
So -18psi on idle is typically the norm? and scott, yeah it goes well into the positive at full chat
Old Nov 29, 2006 | 11:36 AM
ballin's Avatar
ballin
it will have a vacuum yes, but not negative 18 lbs worth !
Old Nov 29, 2006 | 11:39 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
usually around -5psi on vac at idle i think
Nick_RSIFEZ's Avatar
Nick_RSIFEZ
-18, that's fine, it's reading the negative vacuum on idle, then when the turbo cuts in it should go into plus figures, as does the pressure in the plenum or inlet manifold or wherever the takeoff is for the boost gauge!
my frst used to read about -10 - -13 but that was with a cheap boost gauge!
Andreas's Avatar
Andreas
Thats what I wrote "you WONT EVER see that, EVEN when coasting down...." Not my first language so perhaps came out wrong?
Shoot down the others in this thread instead that seem to think that -18 is fine.
Old Nov 29, 2006 | 11:41 AM
Rob84's Avatar
Rob84
thanks for the input guys
Time to ditch the "auto gauge" gauge and get a proper one I think
Old Nov 29, 2006 | 11:44 AM
big_wig_074's Avatar
big_wig_074
-15 or so is what i used to see.
Old Nov 29, 2006 | 11:45 AM
GARETH T's Avatar
GARETH T
the amount of vacuum (even though i dont like that saying) it pulls at idle depends on a few thing,,, (cams bla bla) so dont worry abut the number it if pulling,, aslong as there is a vacuum there your happy
the reason why i was laughing at -18psi,, is because the lowest pressure that is possible to create (nothing-ness) is -14.7psi gauge pressure ( or zero absolute) so minus 18psi,,, is more than nothing
everything in our would has an absolute zero,,, pressure being -14.7 psi gauge, and temp being -273 degrees c below this temp, electrons stop moving and the atom does not excist no more
we really shouldnt use guage pressure,, as zero drifts on guage pressure,,, atmopheric pressure changes by the minute with standard atompheric pressure being 1.013bar absolute, or 14.7psi absolute
Old Nov 29, 2006 | 11:51 AM
Nick_RSIFEZ
^^^ This guy knows his shindig! ^^^ most of what you said just went over my head!
Old Nov 29, 2006 | 11:53 AM
GARETH T's Avatar
GARETH T
btw the scale of the vacuum side might not be PSI,, it could be inches of mercury thats where your getting the 18 from
Old Nov 29, 2006 | 11:58 AM
Terry Tibbs's Avatar
Terry Tibbs
i see -9 on my turbo at idle.. then boosts to +8
Old Nov 29, 2006 | 09:48 PM
GARETH T's Avatar
GARETH T
well get you car chipped and get that boost up
Old Nov 29, 2006 | 10:14 PM
Chris69's Avatar
Chris69
i see -15 on idle and approx -20 when coasting, i'm pretty sure thats not psi though
Old Nov 29, 2006 | 10:41 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Mine reads -9psi on idle - standard car basically is this good or bad on an S1
Old Nov 29, 2006 | 10:43 PM
GARETH T's Avatar
GARETH T
if you read my post a few up,,, you would my 100% that isnt psi
Old Nov 29, 2006 | 10:55 PM
richm's Avatar
richm
-9/10psi is a reasonable normal idle absolute manifold pressure with "sensible" cams.
Old Nov 30, 2006 | 12:35 AM
Ex-Finesse's Avatar
Ex-Finesse
Why on earth are there negative readings on a boost guage in the first place?
Negative pressure is just impossible
Why don't the guages just read into fractions of 1 bar?
Old Nov 30, 2006 | 12:38 AM
MrMPuk's Avatar
MrMPuk
A minius reading at idle is correct this is due to there being a vacuum, all the turbo vehicles I've ever had have read minus at idle.
Old Nov 30, 2006 | 06:55 AM
the original's Avatar
the original
A certain well known tuning garage told me
that one of the first checks they do on a car that comes in is check the idle vacuum with an accurate, large liquid filled gauge
on a standard car it should be x psi (can't remember exactly but something like 10 or 11?)
and if it's not that high (i.e. less vacuum)
then it's an indication of incorrect cam timing, inlet leak or some other problem....
Old Nov 30, 2006 | 08:02 AM
richm's Avatar
richm
Boost gauges indicate "gauge" pressure, ie relative to atmosphere, hence a vacuum is indicated as negative gauge pressure.
Old Nov 30, 2006 | 09:13 AM
Chris69's Avatar
Chris69
my bad dude i only read the first few posts, good explanation btw
Old Nov 30, 2006 | 10:48 AM
R5FORD's Avatar
R5FORD
wa the hell are you guys on about
Old Nov 30, 2006 | 04:11 PM
Chris69's Avatar
Chris69
My boost guage says "in. hg" if that makes any odds to anyone- i'm intrigued as to the units its measured in now
Old Nov 30, 2006 | 05:03 PM
richm's Avatar
richm
in.hg. = "inches of mercury"
nominal atmospheric pressure = 29.92 in.hg.
so nominal idle vacuum of -10psi = 20 in.hg.
Old Nov 30, 2006 | 05:33 PM
Chris69's Avatar
Chris69
thanks rich sorry for hijack
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
