big power fwd gearbox?
#41
just finding my feet
Originally Posted by Rick
Jano posted a guide how to fit an MTX didn't he?
yeah he done 2 different ones depending on the person who wants to attempt it
one of em involved cuting a tiny bit off the chassis leg and welding blah blah blah blah blah blah
the other was drive the peice of shite down to essex with under a grand and a week later theres a box fitted,,,,,,, not a spanner snapped and not 1 knuckle scraped with option 2
for the price off a bernie stage 2+ tbh its another decent conversion done by micheal carrols younger brother
#42
Originally Posted by Stu.H
Ive got a quaiffe diff, cts stage 2 box and 6 paddle, wonder what power it will be ok for
i done two of them boxes now
i need a better box not to blow up the mtx box is the way forward. but to much grif to fit to an mk4 jano done a few now
#44
#45
DEYTUKURJERBS
Originally Posted by Pennywise
Originally Posted by NUTS RuS
125 is fast enough Christian, thats already 55mph over our national speed limit
#47
why do you think he does it for a living and makes money out of it
#48
The Quaife gear kit will give high top speeds if you select the right final drive... it's the close ratio gears that give you the problem if it's not purely for race tracks. If you want a top speed of 150mph, you're looking at a 1st gear capable of about 60mph!
Likewise a 1st gear which'll give 35mph (roughly standard), your top speed drops to about 115mph
I've worked it out every way I can, there's really no trade off if you want good acceleration off the line and still retain a good top speed
Yes, Quaife do a SCCR 6 speed god engagement sequential box, but just because it's all singing, all dancing, it doesn't mean it'll take 300bhp / lbs... does it..
It was used in Ford RS2000 Maxi rally cars, which used high revving 270bhp (200lbs) I4 engines. Even then, it wasn't really up to the job. The 18k Xtrac box was much preffered.
In mk5/6 escorts, to convert from iB5 to MTX75, you have to change the: subframe, engine mounts, driveshafts, hubs, gear linkages... so I suppose all that needs to be done in mk3 & 4s too? Yes in standard form the MTX75 is a stronger box than the iB5 / BC, but I can't really see the point of changing it when a modified iB5 / BC box is proven
#49
the mtx75 has a much nicer shift and can be built to take more power and torque im sure. its a much more modern design so blatantly should be better when someone has worked their magic on it rather than the bc
#50
My mate has a straight cut kit for a F25 vauxhall box, and it does 60 in first, topping out at 160.
My tip, fit a Vauxhall box, we have a standard gearbox that takes the power
#51
You know my mate matt I belive
#54
#55
BC isn't proven though. They break all the time!
That's what I was refering to. It seems they're pretty indestructable.
#56
14000+ post superhero
Re: big power fwd gearbox?
Originally Posted by lloyd
is there a fwd gearbox and diff for a rs turbo capable of taking 420 bhp?
TPM961
15-01-2018 10:50 AM
